Timekeeper Miku
Miku-inspired electronic clock: 2 LED rings for time, messaging screen in speech bubble, created with EAGLE & Fusion 360. Work-in-progress.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Introducing a hobby project of mine - an electronic clock based on an alluring illustration of Miku cradling the Earth by Artist あずきのまめ.
The project was designed using Autodesk's EAGLE and Fusion 360 software. The printed circuit board's front side displays the time through two concentric LED rings for hours and minutes. It also features a screen integrated into a speech bubble for messaging capabilities.
The back side shows the used electronic components that run the board. Although some electrical components are still not installed/soldered yet, the overall design is well on its way to becoming a fully functional clock.
