This video tutorial quick explains all the steps you will need:
All the files required are in the description of the video. Some LEGO type guides are included so anyone can duplicate the project.
Using Old 3D Printer parts I build an Camera Motion Controller
Because of the current consumption of the Motion Controller you will need a anti spark connector if you are using a V mount Battery, because the peak current will trigger the projection circuit of the battery. You can get an anti-spark connector in a drone store or amazon. you will need to put this connector in between the DC connector for the board and your battery.
