1Aditional Notes
Because of the current consumption of the Motion Controller you will need a anti spark connector if you are using a V mount Battery, because the peak current will trigger the projection circuit of the battery. You can get an anti-spark connector in a drone store or amazon. you will need to put this connector in between the DC connector for the board and your battery.
DSLR DIY
