There's an 8K 10.1" Mono LCD (SMP1018K13A0) and matching UV source that is £310 total and has a lot of good stuff:
- Square pixels of 28.5um, compared to 50um for the 8.9" 4K
- 10% transmittance, which is almost double the 5.4% of the 8.9" 4K
- Long edge is 218.88mm, which I believe is only a few millimetres longer than typical A4 scanner sensors (8.5" = 215.9mm)
This is only held back by its low availability:
kelvinA
