Navigation
The title tag system is explained here, and the table is updated when a change occurs. Notable logs have bold L# text.
Preface
[2024 - Aug 2]
I underwent some surface-level research into soap and saw a few mentions to alkalis, so I thought soap + alkali = SecSavr Soapali. It emphasises the need that this solution has to be much cleaner than the current hobbyist MSLA workflows, and the "ali" sounds like "ally" so the name, overall, sounds more approachable and domestic. I've spelt it "alai" to reduce pronunciation ambiguity with "alee".
The minimum goal for this 3D printer is to be able to produce the 3D equivalent of a B+W toner printer, allowing for prints spanning from photorealistic PNGs to "3D colouring book".
I do acknowledge the risky-finish goal (Trackmania-speak) is to integrate a 20W-output blue laser that has a 0.08mm square dot size, allowing for sintering powder-infused photopolymers. My sights are set on copper to be able to fabricate 3DPCBs with at least 0.16mm traces and spacing. For context, the integrated circuit chips in QFN packages I've seen need 0.2mm traces and spacing.
[2023 - May 7]
I've done the research in #SecSavr Suspense [gd0105]. This project is to clean up my some of my concerns and pave the way to a solution, hence the name "Soapavr".
kelvinA
Jaime García
Alexander Bissell
