Floating pins... remember the name, caused me so much headache. Working, I'm using the shared power supply method so I only use 1 plug.
I am using the blue LED as a WiFi connected indicator
RX pin is used later since it can be set to low on boot.
Turns on/off if below/above 80% charge
