No more plastic water bottles at home
Take the first pot and drill a hole at the bottom for the valve.
Drill a hole in one of the lids to make the base of the top pot. Beware of cuts with stainless steel! Use emery cloth to dull the sharp edge.
Open your charcola filters and drill two holes in the bottom of the second tank.
View all instructions
Subhankar Dey
dannyvai
Anteneh Gashaw
jfolks
Yes, delete it Cancel
You are about to report the project "Gravity filter water fountain", please tell us the reason.
