CODE
06/21/2023 at 05:12 • 0 comments#include <FreeRTOS.h>
#include <task.h>
#include <LiquidCrystal_I2C.h>
#include <VNH3SP30.h>
#include "DFRobotDFPlayerMini.h"
#include <DueTimer.h>
#include <ButtonDebounce.h>#define INDUCTION_LEVEL 0
#define MIX_INTERVAL 1
#define COOK_TIME 2
#define NOVA 3
#define PAUSE 4
#define PLAY 5
#define SAUTE_LEVEL 6volatile bool change_flag, set_flag;
bool timerFlag = LOW;
bool playFlag = LOW;//Create the Player object
DFRobotDFPlayerMini player;//Create the motor object
VNH3SP30 strrMotor;
//Create the lcd object
LiquidCrystal_I2C lcd(0x27, 16, 2);char temp[2];
volatile int stoveLevel = 0;
volatile float HeatLevelCounter = 0.0;
volatile int stoveLastState = 0;
unsigned char setHeatCommand[5] = { 0xFF, 0x55, 0x01, 0x00, 0xFE };
bool saute_flag = LOW;
bool induction_flag = LOW;
volatile long int main_count = 0;
bool startBit = LOW;
bool shakeState = LOW;
int timer;
volatile int displayChange = 3;
volatile int displayLastChange = 3;
volatile long int timerSet = 0;
unsigned long int timerPause = 0;
unsigned long int timermillis;
volatile int timerMin;
volatile float sauteLevel = 1.0;
volatile bool sauteBit = LOW;
volatile int sauteLevelSet = 1;
volatile int sauteLevelLastSet = int(sauteLevelSet);//PLAY/PAUSE
#define PP_SWITCH 7//DF PLAYER
#define DF_RX 14
#define DF_TX 15//TIMER ENCODER
#define TIMER_ENC_A 31
#define TIMER_ENC_B 29
#define TIMER_SWITCH 33/*------------------------------------------------------------------STIRRER FUNCTIONS STARTS ------------------------------------------------------------------*/
// Quadrature Encoder Matrix
const int QEM[4][4] = {
{ 0, -1, 1, 2 },
{ 1, 0, 2, -1 },
{ -1, 2, 0, 1 },
{ 2, 1, -1, 0 }
};//enum strrLocations { downLevel1,
// downLevel2,
// downLevel3,
// downLevel4
// };const int strrPosMatrix[5] = { -1500, -2500,
-3500,
-4500,
-5500
};volatile long int strrEncoder = 0;
volatile unsigned char strrNew, strrOld;
int sauteState, sauteLastState;
volatile float sauteCounter = 0.0;
volatile int sauteSet;//MOTOR DRIVER
#define MOT_IN1 9
#define MOT_IN2 10
#define MOT_PWM 8//stirrer rotary encoder
#define SAUTE_ENCA 35
#define SAUTE_ENCB 39
#define SAUTE_SWITCH 37//BLDC
#define STRR_BLDC_DIR 53
#define STRR_BLDC_PWM 51
//#define STRR_BLDC_FDBK 10//LIMIT SWITCH
#define STRR_VER_TOP_LMT 25
#define STRR_VER_BTM_LMT 27//Stirrer motor encoder
#define STRR_VERT_ENC_A 47
#define STRR_VERT_ENC_B 49#define STRR_CW() \
digitalWrite(STRR_BLDC_PWM, LOW); \
digitalWrite(STRR_BLDC_DIR, HIGH); \
}#define STRR_CCW() \
digitalWrite(STRR_BLDC_PWM, HIGH); \
digitalWrite(STRR_BLDC_DIR, LOW); \
}#define STRR_STOP() \
}#define STRR_UP() \
analogWrite(MOT_PWM, 70); \
digitalWrite(MOT_IN1, LOW); \
digitalWrite(MOT_IN2, HIGH); \
#define STRR_DOWN() \
digitalWrite(MOT_IN1, HIGH); \
digitalWrite(MOT_IN2, LOW); \
}#define STRR_VER_STOP() \
digitalWrite(MOT_PWM, LOW); \
}void enAStrInterrupt() {
strrNew = (digitalRead(STRR_VERT_ENC_A) << 1) | (digitalRead(STRR_VERT_ENC_B));
strrEncoder += QEM[strrOld][strrNew];
strrOld = strrNew;
}void enBStrInterrupt() {
strrOld = strrNew;
}void shake() {
if (shakeState == LOW) {
shakeState = HIGH;
STRR_CW();
} else {
shakeState = LOW;
STRR_CCW();
}void strrMovDown() {
STRR_DOWN();
while (strrEncoder < 400) ;
Timer2.attachInterrupt(shake).start(350000);
while (digitalRead(STRR_VER_BTM_LMT) != HIGH);
STRR_VER_STOP();
Timer2.stop();
}void strrMovUp() {
STRR_UP();
while (digitalRead(STRR_VER_TOP_LMT) != HIGH);
STRR_VER_STOP();
}void moveStirrerTo(int pos) {
int Threshold = -20;
int HighTreshold = -5000;
int error = 0;
int target = strrPosMatrix[pos];
error = target - strrEncoder;
strrMotor.setSpeed(-300);while (1) {
if (error < HighTreshold) {
} else if ((error > HighTreshold) && (error < Threshold)) {
strrMotor.setSpeed(-80);
} else if ((error > HighTreshold) && (error > Threshold)) {
strrMotor.brake(500);
if (error > Threshold) {
break;
}void strrHome() {
if (digitalRead(STRR_VER_TOP_LMT) != HIGH) {
Serial.println("Stirrer moving Home");
strrMovUp();
strrEncoder = 0;
Serial.println("Stirrer Homing completed");
}void oneMix() {
Serial.println("One mix started");
STRR_CW();
int lastState = millis();
while (millis() - lastState <= 3200) {
if (startBit == LOW) break;
STRR_STOP();
while (millis() - lastState <= 200) {
STRR_CCW();
STRR_STOP();
Serial.println("One mix finished");
}void saute() {
if (startBit == HIGH) {
strrMovDown();
strrEncoder = 0;
if (startBit == HIGH) oneMix();
for (int i = 0; i <= sauteLevelSet; i++) {
if (startBit == HIGH && sauteLevelSet > 1) moveStirrerTo(i-2);
if (startBit == HIGH) STRR_CW();
while (millis() - lastState <= 4000) {
STRR_STOP();
if (startBit == LOW) inductionOff();
strrEncoder = 500;
}volatile int sauteLastSet = int(sauteCounter);
void sauteEnAIsr() {
if (change_flag == LOW) change_flag = HIGH;
if (sauteBit == LOW) {
if (displayChange != 1) displayChange = 1;
if ((int(sauteCounter) >= 0) && (int(sauteCounter) <= 600)) {
sauteState = digitalRead(SAUTE_ENCA);
if (sauteState != sauteLastState) {
if (digitalRead(SAUTE_ENCB) != sauteState) {
sauteCounter += 0.5;
} else {
sauteCounter -= 0.5;
sauteLastState = sauteState;
if (sauteCounter < -1.0) sauteCounter = -1.0;
else if (sauteCounter > 600.0) sauteCounter = 600.0;
// change_flag = LOW;
// set_flag = HIGH;
saute_flag = HIGH;
// Timer1.stop();
// sauteSet = int(sauteCounter) * 30;
else {
if (displayChange != 6) displayChange = 6;
if ((int(sauteLevel) >= 0) && (int(sauteLevel) <= 5)) {
sauteLevel += 0.5;
} else {
sauteLevel -= 0.5;
if (sauteLevel < 0.0) sauteLevel = 0.0;
else if (sauteLevel > 5.0) sauteLevel = 5.0;
// set_flag = HIGH;
// saute_flag = HIGH;
// Timer1.stop();
}void sauteEnBIsr() {
} else {
if (sauteCounter < 0.0) sauteCounter = 0.0;
// set_flag = HIGH;
saute_flag = HIGH;
// Timer1.stop();
else {
sauteLevel += 0.5;
} else {
sauteLevel -= 0.5;
// set_flag = HIGH;
// Timer1.stop();
}void sauteSwitchIsr() {
set_flag = HIGH;
saute_flag = HIGH;
Timer1.stop();
change_flag = LOW;
}/*------------------------------------------------------------------STIRRER FUNCTIONS ENDS ------------------------------------------------------------------*/
/*-----------------------------------------------------------------INDUCTION FUNCTION STARTS------------------------------------------------------------------*/
//INDUCTION ENCODER
#define INDUCTION_ENC_A 43
#define INDUCTION_ENC_B 45
#define INDUCTION_SWITCH 41//INDUCTION UART
#define INDUCTION_TX 16
#define INDUCTION_RX 17int aState;
int aLastState;
char indtemp[2];const unsigned char onCommand[5] = { 0xFF, 0x55, 0x00, 0x00, 0xFE };
const unsigned char cookCommand[5] = { 0xFF, 0x55, 0x01, 0x08, 0xFE };
const unsigned char offCommand[5] = { 0xFF, 0x00, 0x00, 0x00, 0xFE };
const unsigned char queryCommand[5] = { 0xFF, 0x77, 0x0F, 0x0F, 0xFE };
unsigned char inputBuf[9];
int i;int inductionOn() {
Serial2.write(onCommand, 5); //Turning on(Standby)
delay(500);
Serial2.write(cookCommand, 5); //Cook Command(Hot pot fn)
delay(500);
Serial2.write(queryCommand, 5); //Sending query command
delay(500);
for (i = 0; i < 9; i++) {
while (!Serial2.available())
inputBuf[i] = Serial2.read();
}if ((inputBuf[1] == 0x55) && (inputBuf[2] == 0x01) && (inputBuf[7] == 0x00)) { // (on/off),fn & fault signal
Serial.println("Started cooking");
return 0;
} else if (inputBuf[7]) {
Serial.println("\nInduction fault ");
return (inputBuf[7] * -1);
} else {
Serial.println("Not able to turn on the stove ");
return (-9);
}int inductionOff() {
Serial2.write(offCommand, 5); //Induction turning off
delay(500);
if ((inputBuf[1] == 0x00) && (inputBuf[2] == 0x00)) { //cheching (on/off) & function,power
return 1;
} else {
return (-9);
}int setinductionHeatLevel(int level) {
setHeatCommand[3] = level;
Serial2.write(setHeatCommand, 5);
delay(500);
delay(500);
while (!Serial1.available())
inputBuf[i] = Serial1.read();
if ((inputBuf[1] == 0x55) && (inputBuf[3] == level)) return 0;
} else {
Serial.println("not able to change heat level ");
return (-9);
}void inductionEncIsrA() {
if (displayChange != 0) displayChange = 0;
aState = digitalRead(INDUCTION_ENC_A);
if ((HeatLevelCounter >= 0.0) && (HeatLevelCounter <= 12.0)) {
if (aState != aLastState) {
if (digitalRead(INDUCTION_ENC_B) != aState) {
HeatLevelCounter += 0.5;
} else {
HeatLevelCounter -= 0.5;
aLastState = aState;
if (HeatLevelCounter < 0.0) HeatLevelCounter = 0.0;
else if (HeatLevelCounter > 12.0) HeatLevelCounter = 12.0;
// set_flag = HIGH;
// stoveLevel = int(HeatLevelCounter);
// setHeatCommand[3] = stoveLevel;
}void inductionEncIsrB() {
} else {
// set_flag = HIGH;
}void inductionSwitchIsr() {
set_flag = HIGH;
change_flag = LOW;
}/*-----------------------------------------------------------------INDUCTION FUNCTION ENDS------------------------------------------------------------------*/
/*-----------------------------------------------------------------TIMER FUNCTIONS START---------------------------------------------------------------------*/
int timerState;
int timerLastState;
volatile float timerCount = 0.0;
volatile int timerLastCount = int(timerCount);
char heatLevel[2];
void timerEnAIsr() {
if (displayChange != 2) displayChange = 2;
timerState = digitalRead(TIMER_ENC_A);
if (timerCount >= 0.0) {
if (timerState != timerLastState) {
if (digitalRead(TIMER_ENC_B) != timerState) {
timerCount += 0.5;
} else {
timerCount -= 0.5;
if (timerCount < 0.0) {
timerCount += 0.5;
timerLastState = timerState;
}void timerEnBIsr() {
timerCount += 0.5;
} else {
timerCount -= 0.5;
timerCount += 0.5;
}void TimerStart() {
if (startBit == HIGH && timerSet > 0) {
timerFlag = HIGH;
timerSet -= 1;
}void timerSwitchIsr() {
change_flag = LOW;
set_flag = HIGH;
timerSet = int(timerCount) * 60;
}//void ppIsr() {
// if (startBit == LOW) {
// startBit = HIGH;
// else {
// displayChange = 4;
// startBit = LOW;
// player.play(3);
volatile bool resumeBit = LOW;
void taskOne(void *pvParameters)
while (1) {
// Serial.println("waiting");
if (sauteLevelSet > 0) saute();
else if(sauteLevelSet == 0) strrHome();
int lastMillis = millis();
while (millis() - lastMillis <= (sauteSet * 1000)) {
inductionOff();
strrHome();
volatile int timerLastSet = 0;
volatile int count = 0;
int buttonState; // the current reading from the input pin
void taskTwo(void *pvParameters) {
while (1) {
if ((startBit == HIGH) && (change_flag == LOW) /*&& (timerFlag == HIGH)*/ && timerLastSet != timerSet) {
if (displayChange != 5) displayChange = 5;
timerLastSet = timerSet;
// int(timerCount) = timerSet / 60;
if (displayChange != displayLastChange) {
displayLastChange = displayChange;
lcd.clear();
lcd.setCursor(11, 0);
lcd.print("TIMER");
lcd.setCursor(0, 0);
lcd.print("HEAT");
sauteBit = LOW;
vTaskDelay(30);
// if(startBit == LOW) inductionOff();
sprintf(heatLevel, "%2d", stoveLastState);
lcd.setCursor(0, 1);
lcd.print(heatLevel);
if (stoveLevel != stoveLastState) {
stoveLastState = stoveLevel;
if (stoveLevel == 0) {
else {
setHeatCommand[3] = stoveLastState;
// Serial.println(timerSet);
if (timerSet % 2 == 0)
if (((int(timerSet/2) + 60) / 3600) > 0) {
lcd.setCursor(5, 1);
sprintf(temp, "%2d", ((int(timerSet/2) + 60) / 3600));
lcd.print(temp);
lcd.setCursor(7, 1);
lcd.print("H");
lcd.setCursor(8, 1);
lcd.print(" ");
if (((int(timerSet/2) / 60) % 60) > 0) {
lcd.setCursor(6, 1);
lcd.print(" ");
lcd.setCursor(9, 1);
sprintf(temp, "%02d", ((int(timerSet/2) / 60) % 60));
lcd.print(temp);
lcd.setCursor(11, 1);
lcd.print("M");
lcd.setCursor(12, 1);
lcd.print(" ");
if (((int(timerSet/2) / 60) % 60) == 0) {
lcd.print(" ");
lcd.setCursor(13, 1);
sprintf(temp, "%02d", int(timerSet/2) % 60);
lcd.print(temp);
lcd.setCursor(15, 1);
lcd.print("S");
else
lcd.print(temp);
lcd.print("H");
lcd.print(":");
lcd.print(" ");
lcd.print(temp);
lcd.print("M");
lcd.print(":");
lcd.print(" ");
lcd.print(temp);
lcd.print("S");
if (timerSet == 0) {
startBit = LOW;
resumeBit = LOW;
player.play(6);
lcd.clear();
lcd.setCursor(5, 0);
lcd.print("COOKING");
lcd.setCursor(4, 1);
lcd.print("COMPLETED");
inductionOff();
stoveLevel = 0;
stoveLastState = 0;
sauteLevel = 1.0;
sauteLevelSet = 1;
timerCount = 0.0;
sauteCounter = 0.0;
strrHome();
int displayLastState = millis();
while (millis() - displayLastState <= 3000) {
if (change_flag == HIGH) break;
// displayChange = 3;
if (change_flag == LOW) displayChange = 3;
timerFlag = LOW;
// timerFlag = LOW;
else if ((change_flag == HIGH) || (startBit == LOW)) {
switch (displayChange) {
case INDUCTION_LEVEL:
// if ((stoveLevel) != int(HeatLevelCounter)) {
lcd.clear();
vTaskDelay(30);
sauteBit = LOW;
lcd.print("INDUCTION LEVEL");
setHeatCommand[3] = int(HeatLevelCounter);
lcd.setCursor(3, 1);
lcd.print("LEVEL:");
sprintf(indtemp, "%2d", setHeatCommand[3]);
lcd.print(indtemp);
break;case MIX_INTERVAL:
// if ((sauteLastSet) != int(sauteCounter)) {
lcd.clear();
vTaskDelay(30);
lcd.setCursor(2, 0);
lcd.print("MIX INTERVAL");
lcd.setCursor(2, 1);
sprintf(temp, "%2d", (int(sauteCounter) * 15) / 60);
lcd.print(temp);
lcd.print("Min");
lcd.print(":");
sprintf(temp, "%02d", (int(sauteCounter) * 15) % 60);
lcd.print(temp);
lcd.setCursor(10, 1);
lcd.print("Sec");
break;case SAUTE_LEVEL:
// if ((sauteLevelLastSet) != int(sauteLevel)) {
lcd.clear();
vTaskDelay(30);
sauteLevelLastSet = int(sauteLevel);
lcd.setCursor(3, 0);
lcd.print("MIX LEVEL");
sprintf(indtemp, "%2d", int(sauteLevel));
if(int(sauteLevel) == 0) lcd.print("NO");
else lcd.print(indtemp);
break;case COOK_TIME:
// if ((timerLastCount) != int(timerCount)) {
lcd.clear();
vTaskDelay(30);
sauteBit = LOW;
lcd.setCursor(4, 0);
lcd.print("COOK TIME");
sprintf(temp, "%2d", (int(timerCount) * 60) / 3600);
lcd.print(temp);
lcd.print("Hr");
lcd.print(":");
sprintf(temp, "%02d", ((int(timerCount) * 60) / 60) % 60);
lcd.print(temp);
lcd.print("Min");
break;case PAUSE:
lcd.clear();
vTaskDelay(30);
lcd.setCursor(10, 0);
lcd.print("PAUSED");
if (((timerSet + 60) / 3600) > 0) {
lcd.print(temp);
lcd.print("H");
lcd.print(":");
if (((timerSet / 60) % 60) > 0) {
lcd.print(temp);
lcd.print("M");
lcd.print(":");
lcd.print(temp);
lcd.print("S");
break;case NOVA:
lcd.clear();
vTaskDelay(30);
lcd.setCursor(6, 0);
lcd.print("NOVA");
lcd.setCursor(1, 1);
lcd.print("LET'S COOK ");
switch (count % 3) {
case 0:
lcd.print(">> ");
break;
case 1:
lcd.print(" >> ");
break;
case 2:
lcd.print(" >>");
count = -1;
break;
default:
break;
// count++;
break;default:
break;
long int mainLastState = millis();
while (millis() - mainLastState <= 1500 && displayChange != NOVA) {
if ((change_flag == HIGH) || ((displayLastChange != displayChange) && displayChange != PLAY) || buttonState == HIGH) break;
if ((change_flag == LOW) || (displayLastChange != displayChange)) {
switch (displayLastChange) {
sauteSet = int(sauteCounter) * 15;
timerSet = int(timerCount) * 120;
sauteLevelSet = int(sauteLevel);
break;default:
break;
set_flag = LOW;
while ((millis() - lastMillis) <= 1500 && displayChange != NOVA) {
if (change_flag == HIGH || ((displayLastChange != displayChange) && displayChange != PLAY) || buttonState == HIGH) break;
}void taskThree(void *pvParameters) {
unsigned long lastDebounceTime = 0; // the last time the output pin was toggled
unsigned long debounceDelay = 50;
int lastButtonState = LOW;
while (1) {
int reading = digitalRead(PP_SWITCH);
if (reading != lastButtonState) {
lastDebounceTime = millis();
}if ((millis() - lastDebounceTime) > debounceDelay) {
if (reading != buttonState) {
buttonState = reading;
if (buttonState == HIGH) {
Serial.println("PRESSED");
startBit = HIGH;
// Serial2.write(setHeatCommand, 5);
stoveLastState = 0;
if (resumeBit == LOW) player.play(11);
else player.play(4);
if(resumeBit == LOW) resumeBit = HIGH;
else if (startBit == HIGH) {
displayChange = 4;
startBit = LOW;
player.play(3);
lastButtonState = reading;
}void sound() {
player.play(12);}
void taskFour(void *pvParameters) {
playFlag = LOW;
while (1) {
if (playFlag == HIGH) {
sound();
// vTaskDelay(1000);
}void taskFive(void *pvParameters) {
while (1) {
if (change_flag == HIGH) {
vTaskDelay(50);
change_flag = LOW;
}void taskSix(void *pvParameters) {
unsigned long LastDebounceTime = 0; // the last time the output pin was toggled
unsigned long DebounceDelay = 100;
int ButtonState; // the current reading from the input pin
int LastButtonState = HIGH;
char sauteTemp[2];
while (1) {
int Reading = digitalRead(SAUTE_SWITCH);
if (Reading != LastButtonState) {
LastDebounceTime = millis();
}if ((millis() - LastDebounceTime) > DebounceDelay) {
if (Reading != ButtonState) {
ButtonState = Reading;
if (ButtonState == LOW) {
// Serial.println("PRESSED");
if (sauteBit == HIGH) {
sauteBit = LOW;
displayChange = 1;
change_flag = HIGH;
else if (sauteBit == LOW) {
sauteBit = HIGH;
displayChange = 6;
change_flag = HIGH;
LastButtonState = Reading;
}void countStart() {
if (displayChange == NOVA) count += 1;
// if(count == 3) count = 0;
}/*******************************TIMER FUNCTIONS END***********************************/
void setup() {
Serial.begin(9600);
Serial1.begin(9600);
Serial2.begin(9600);
Serial3.begin(9600);
pinMode(MOT_IN1, OUTPUT);
pinMode(MOT_IN2, OUTPUT);
pinMode(MOT_PWM, OUTPUT);
pinMode(STRR_VER_BTM_LMT, INPUT);
pinMode(STRR_VER_TOP_LMT, INPUT);
pinMode(STRR_BLDC_DIR, OUTPUT);
pinMode(STRR_BLDC_PWM, OUTPUT);
pinMode(SAUTE_SWITCH, INPUT);
// pinMode(INDUCTION_SWITCH, INPUT_PULLUP);
strrMotor.begin(MOT_PWM, MOT_IN1, MOT_IN2);
pinMode(TIMER_ENC_A, INPUT_PULLUP);
pinMode(TIMER_ENC_B, INPUT_PULLUP);
pinMode(SAUTE_ENCA, INPUT_PULLUP);
pinMode(SAUTE_ENCB, INPUT_PULLUP);
pinMode(INDUCTION_ENC_A, INPUT_PULLUP);
pinMode(INDUCTION_ENC_B, INPUT_PULLUP);
// pinMode(TIMER_SWITCH, INPUT_PULLUP);
pinMode(PP_SWITCH, INPUT);
attachInterrupt(digitalPinToInterrupt(STRR_VERT_ENC_A), enAStrInterrupt, CHANGE);
attachInterrupt(digitalPinToInterrupt(STRR_VERT_ENC_B), enBStrInterrupt, CHANGE);
attachInterrupt(digitalPinToInterrupt(INDUCTION_ENC_A), inductionEncIsrA, CHANGE);
attachInterrupt(digitalPinToInterrupt(INDUCTION_ENC_B), inductionEncIsrB, CHANGE);
attachInterrupt(digitalPinToInterrupt(SAUTE_ENCA), sauteEnAIsr, CHANGE);
attachInterrupt(digitalPinToInterrupt(SAUTE_ENCB), sauteEnBIsr, CHANGE);
attachInterrupt(digitalPinToInterrupt(TIMER_ENC_A), timerEnAIsr, CHANGE);
attachInterrupt(digitalPinToInterrupt(TIMER_ENC_B), timerEnBIsr, CHANGE);
// attachInterrupt(digitalPinToInterrupt(TIMER_SWITCH), timerSwitchIsr, FALLING);
// attachInterrupt(digitalPinToInterrupt(SAUTE_SWITCH), sauteSwitchIsr, FALLING);
// attachInterrupt(digitalPinToInterrupt(INDUCTION_SWITCH), inductionSwitchIsr, FALLING);
// attachInterrupt(digitalPinToInterrupt(PP_SWITCH), ppIsr, RISING);
Timer3.attachInterrupt(TimerStart).start(500000);
Timer4.attachInterrupt(countStart).start(500000);
inductionOff();
// Init serial port for DFPlayer Mini
if (player.begin(Serial3)) Serial.println("Player-OK");
lcd.init();
lcd.backlight();
lcd.clear();
// lcd.print("NOVA");
// player.play(10);
// delay(3000);
displayChange = 3;
xTaskCreate(taskOne, (const portCHAR *)"taskOne", 128, NULL, 1, NULL);
xTaskCreate(taskTwo , (const portCHAR *)"taskTwo", 256, NULL, 1, NULL);
xTaskCreate(taskThree , (const portCHAR *)"taskThree", 128, NULL, 1, NULL);
// xTaskCreate(taskFour , (const portCHAR *)"taskFour", 256, NULL, 1, NULL);
xTaskCreate(taskFive , (const portCHAR *)"taskFive", 128, NULL, 1, NULL);
xTaskCreate(taskSix , (const portCHAR *)"taskSix", 128, NULL, 1, NULL);
vTaskStartScheduler();
saute_flag = HIGH;// strrHome();
// delay(2000);
// strrMovDown();
//// inductionOff();
//// delay(1000);
// inductionOn();
// delay(2000);
// inductionOff();
// setinductionHeatLevel(3);
}void loop() {
// STRR_CW();
// delay(8000);
// STRR_CCW();
// delay(4000);}
