I'm definitely using these reference cards, and occasionally I find mistakes or inconsistencies.
Revision 3 is released, with following changes from Revision 2:
- CD40106 alternate part is MC14584.
Previously it was incorrectly marked MC14568. - CD4572U inverter input and output pins are now correctly labeled.
Previously the outputs were swapped with inputs. - CD40110 borrow and carry are active-low and are marked as such.
Previously they were shown as active-high (positive) logic. - A bonus analog-like-it's-the-70s sheet is added, revision 0, with references for:
- LM339, LM2901 quad comparators,
- LM324, LM2902 quad op-amps (industry standard pinout),
- LM393, LM2903 double comparators,
- LM358, LM2904, TLC262 double op-amps (industry standard pinout),
- recommended connections for unused op-amps and comparators above,
- 2N2222/ZTX455 and 2N2907/ZTX555 transistors,
- 78xx and 79xx TO-252 regulators,
- LM334 current source pinout and design equation,
- TL431A voltage reference pinout and design equation
![](https://cdn.hackaday.io/images/158471706220859409.jpg)
