1Preparation
In the DIY Kit you have purchased from Tindie, you will get a bare PCB of Muscle BioAmp Shield v0.3 and to start the assembly process It is recommended to keep the Interactive BOM link handy to make the assembly process a breeze!
21M Resistors
Solder 1M resistors at R1 and R2
3330R Resistors
Solder 330R resistors at R13 to R18
410K Resistors
Solder 10K resistors at R12, R19, and R20
522K Resistors
Solder 22K resistors at R6 and R7
61K Resistors
Solder 1K resistors at R3, R9, and R10
7220K Resistors
Solder 220K sesistors at R4, R5, R8, and R11
81nF Capacitors
Solder 1nF capacitors at C4 and C7
9100nF Capacitors
Solder 100nF capacitors at C2, C9, and C11
10100pF Capacitors
Solder 100pF capacitors at C3, C5, and C8
Deepak Khatri
