Frequency Response
06/13/2023 at 19:02 • 0 commentsI was really bothered about the frequency response, so I decided to take some measurements.
I used REW (Room EQ Wizard), and got a very flat response for a direct cable.. but a (I think) quite bad for my mixer :(.![]()
(blue is -48 dBFS, pink Phase)
I will try to get more adequate Op Amps, and maybe tweak the dc coupling.
Also somehow I think I do not output enough volume... and I used 15 volts for that.... so maybe I will have to redesign it all?
Suggestions are appreciated!
Removed USB power noise.
06/02/2023 at 08:30 • 0 commentsI received my set of 78xx linear regulators and did some fast test to check if it removes the USB power noise.. and it does!
So I set together a fast protoboard to try it live with the full mixer, and the noise level is now non existant! Amazing!
Now I have another problem to solve and is that I'm filtering out low frequencies. Quite probably is the DC bias removal. Need to investigate.
David Moreno Montero
