My new design is close to the classcial design, with some small, but for my opinion significant changes:
- The computing elements are plugged into the connection board, thus it is possible to archive calculations.
- As the computing elements are pluggable, the configuration can be adapted; there is no other limit for the computing elements than the number of slols.
- Computing elements have a current input as primary input, thus avoiding a lack of input menans.
- Potentiometeres deliver a current, not a voltage; thus can be calibrated in advance.
- Digitally set potentimeters allow quick and precise setup.
- The modules can be configured with jumpers for various functions.
- Integrators have a very quick initialisation circuit and can thus be used as track-and-hold
- Initial conditions for integrators can be set with potentiometers on the module, but also via a current input.
- The adder has options to function as (inverting) adder, precision rectifier or comparator; no free wiring of components is required.
- Potentiometers have a (digital) switch than can disable the output; so more than one signal can be switched directly, and no switches are necessary on calculating modules.
- Power supply is only (precise) 30V DC. Calculations use ±10V.
- A module is small: 100mm x 14mm and can be made on perfboard with 2.54mm spacing.
- Connections use a common and affordable prototype plugboard.
- Repetitive operation not yet provided
Rainer Glaschick
icstation
Denys Zaikin
Andrew Starr
Thank you. Although it was made as a proot-of-concept for the changes with respect to the classical solution, I thought it might be useful for this community.
