The next step is to use Quartz fork. I've bought sime 2x8mm 32KHz Quartz oscillators. Now the tricky part is to gently remove enclosed without breaking the Quartz fork. I've preferred to use small file to remove metallic encapsulation. (Although it's tempting to put Quartz fork into something like a drill, I was afraid that centrifugal force will damage this tiny fork)
