Inspiration:
CH552G programing:
Test ws2812b mini (3535) with PIC12F1822 32MHz internal
Now I use RP2040 (PI PICO) + CircuitPython +Thonny ( IDE )
Components:
Mechanical keyboard with led ws2812b mini(3535)...
Inspiration:
CH552G programing:
Components:
modul_imk6k.zipeasyEDA module project for macro keyboard imk6kZip Archive - 24.81 kB - 10/28/2024 at 08:09 |
what I wanted to know is if you could change then individually, or integrate a config in the software. For example when I press on windows key I want certain keys to light a certain color or not light up
I can't reply to the second comment so I'll reply here: Yes you can change individual leds (color, brightness) it just has to be programmed but you need leds ws2812 or sk6812.
In the video "mechanical keyboard 2" at the end, I press Fn+R =red... Next, at Fn+ESC, the keyboard profile changes and the numbers 1-4 glow white according to the current profile
I love mechanical keyboard and always recommended Gateron oil king linear switches you should also use for gaming or typing https://mechswitcher.com/gateron-oil-king-linear-switches/
I'm not use a led but knob is good idea , what You think about this layout ? https://klawiatura.wordpress.com/ I hate altgr but in my language I have more chars than latin
This is my first keyboard design and the action ending on elecrow.com (5pcs pcb 10$) so I missed the knob. Layout is nice but i key caps for my language(Slovak) is hard find
could you individually change each LED? If it's not possible how would you go about that?
