Automatic decapsulation chamber
A project log for Integrated Circuit decapping without acid
IC are amazing, but always closed in eopch which seems impossible to remove. Here we propose a method to decap without acids
quasi-scientistQuasi Scientist 11/13/2023 at 02:520 Comments
The idea is to make a box with Tesla coil that produces plasma powerful fan that could control plasma shape and Faraday cage to hold all the energy inside.
Let's start with a box it has a side window to see how far plasma from the chip. Upper opening to let air in and lower opening to let the air out.
Inside we have a metalic tray that could be height adjusted.
Trial run looks good
