Hackaday.io Hackaday.io
Sign up Log in
Remoteduino Nano
Tiny DIY programmable IR remote that's based off the arduino uno (backwards compatible with my orginal Remoteduino project)!
sjm4306sjm4306
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
1.6k views
2 comments
17 followers
  • Description
  • Details
  • Files 4
    • View all
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 2
View Gallery
Public Chat
1.6k
2
17
15
Team (3)
  • sjm4306sjm4306
  • dtsombolovD.Tsombolov
  • laurin-cavenderLaurin Cavender
Join this project's team
hardware
ongoing project
arduino ATMEGA infrared ir remote programmable diy
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 06/13/2023 and last updated 3 years ago.
Description
Basically a more refined version 2 of my original Remoteduino project, which was an arduino compatible programmable IR remote. The nano is even smaller and adds an onboard IR receiver to allow programming buttons on the fly from other remotes (software is still a work in progress on that front, but hard coded remote commands currently work). Room for 5mm 950nm IR led. Runs off a single CR2032 and while not in use the atmega328p sleeps. Hard power switch in case you want to store the remote for longer periods without draining the battery. Onboard pogo pads for icsp and serial programming. Oh yeah and I added a cute little keyring hole just because ...
Files
IRnano_test.ino
Test firmware, not final!
ino - 3.26 kB - 06/13/2023 at 13:16
Download
remoteduino nano.sch
Eagle Schematic
sch - 668.65 kB - 06/13/2023 at 13:15
Download
remoteduino nano_2022-04-04.zip
PCB Gerbers
x-zip-compressed - 175.15 kB - 06/13/2023 at 13:15
Download
remoteduino nano.brd
Eagle PCB
brd - 111.15 kB - 06/13/2023 at 13:15
Download
Project Logs
Collapse
  • Video Demo
    sjm4306 • 06/13/2023 at 13:17 • 0 comments
View project log
Log In/Sign up to comment
Sign up with Github
OR
richteel wrote 06/19/2023 at 12:30 • point
I had built a similar remote many years ago for my mother-in-law so she could press a button and send commands to several devices at a time. It worked well but I see you opted to do the same thing by having a power switch to turn the remote on and off. One of the things that I've thought would have made the project better is if it was like a true remote and did not need to be powered off to allow the battery to last a long time. It looks like you did some things to make it lower power but I assume the CR2032 battery would only last a couple of days, if that, without being switched off.
I was also looking into creating a Roku remote replacement so you can actually key in the channel you want to watch rather than using the up/down channel buttons but it appears that Roku does not have IR codes to actually input a channel directly. This is a source of frustration with folks who watch over the air TV with their Roku TVs.
sjm4306 wrote 06/19/2023 at 12:49 • point
Measuring the current draw in standby to be in the range of ~30uA, I calculated the battery should last at least a year with the power switched on. I've still got some peripherals turned on though so it's not the lowest power state it could achieve (iirc the atmega328p can go down to something like 4uA). I really only added the switch for even longer term storage or just to prevent it from wasting power while in the pocket if a button is accidentally pressed.
Hackaday Prize 2019
When a magician rotates his magical wand and says 'Abracadabra', magic happens! This IoT Magical Wand project is inspired by this.
Project Owner Contributor
IoT Magical Wand
dixon-selvanDixon Selvan
The 2015 Hackaday Prize
An affordable RFID, motion-sensing, anti-theft alarm and GPS tracker for bicycles, e-bikes and other small vehicles. Based on Arduino
Nano Bike Alarm
alpha-charlieAlpha Charlie
Turn a LED on and off using voice commands
Simple Voice Recognition With 1Sheeld
frank-vigilanteFrank Vigilante
The 2017 Hackaday Prize
The goal of this project is to get non-blocking analogRead()'s added to Arduino core libraries.
Non-blocking analogRead()'s for Arduino
jacob-christJacob Christ
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Remoteduino Nano", please tell us the reason.
Send message
Remove Member
