Creating a BIOS extension
A project log for PCjrCart
Custom cartridge for IBM PCjr
shaosSHAOS 01/13/2017 at 05:1114 Comments
So cartridges in PCjr are actually PC BIOS extensions with 055h 0AAh in the beginning and this is how they checked on boot:
with step 2K it's looking for 0x55 0xAA signature and then check CRC:
And this piece shows how BIOS determines which algorithm to use - CRC16 or simple arithmetic sum:
So in order to create proper BIOS extension I wrote CRC16 library compatible with IBM's CRC_CHECK (see here) and special program that creates ROM image from COM-file (for now it has to be specifically created "read-only" COM-file) and put CRC at the end of that ROM image - PCJRCART.C
And this is my 1st program (pictured as title image of the project):
       org 100h
section .text
start:
       MOV     BH,7 ; 0 for DOSBox
       MOV     BL,4
       MOV     CX,1
       MOV     DH,18
       MOV     DL,0
       LEA     SI,[STRI]
NEXT:  MOV     AH,2
       INT     10H
       INC     DX
       MOV     AL,[SI]
       CMP     AL,'$'
       JE      KON
       MOV     AH,9
       INT     10H
       INC     SI
       JMP     SHORT NEXT
KON:   JMP     KON
section .data
STRI   DB      'Hello, Hackaday ! $'
Program is compilable by this command (you need NASM):
nasm test1.asm -fbin -o test1.com
now it could be tested in DOSBox for example or from DOS prompt on real machine and then pcjrcart test1.com to produce test1.bin that could be directly written into AT28C256 (or AT28C64 if size<=8K)
UPDATE: This approach (with some tweaks) was successfully used for PC XT machine by @esot.eric :)
https://hackaday.io/project/18868-improbable-secret-project/log/51957-we-have-a-bios-extension
Rich text editor
Eric Hertz wrote 01/15/2017 at 18:59 point
FYI, found out the hard way... PCjr's method for verifying the BIOS extension is different than PC/XT's (which just uses a checksum, rather'n a CRC) :)
This is handy, either way... I've got my .COM running!
SHAOS wrote 01/16/2017 at 00:37 point
Excellent :)
I added another photocopy of the Tech Reference above to show how everything is working together - PCjr BIOS checks CRC16 for adresses above D0000 and simple sum below D0000:
https://cdn.hackaday.io/images/2168391484526882855.jpg
And yes, now I have paper version of "PCjr Technical Reference" (bought as "brand new") with SCHEMATICS!!! :)
Eric Hertz wrote 01/16/2017 at 09:15 point
Awesome!
I see, now the test you're talking about... I'll have to look more thoroughly at the XT code, as it does seem to treat "rom" as differently from "ros" (whatever that is).
It's funny, about 6 months ago I sold a PCjr that'd been sitting around in my storage for decades, even had the paper techref, but didn't look into it thoroughly enough to realize it had that level of detail. I thought it just talked about how to install floppy drives, printers, etc. But I never really used the PCjr, it was given to me after I'd gotten used to my PC/XT (from a garage sale with *boxes* of stuff for $20!).
SHAOS wrote 01/16/2017 at 13:46 point
@esot.eric Do you have some leftover by the way from that PCjr? As software, cables, extension boards, mice etc? :)
Eric Hertz wrote 01/16/2017 at 14:26 point
@Shaos well, now I wish I did... Would you believe it had two copies of the manual and some other docs... Was trying to recover space, so made sure *everything* went with it :/
SHAOS wrote 01/16/2017 at 14:38 point
Unbelievable :)
Eric Hertz wrote 01/13/2017 at 07:28 point
Was just browsing the XT's BIOS assembly-listing a few weeks ago... I find it utterly amazing they actually make that detailed info available, and the comments are so thorough!
Is it too early in the process to ask what you plan to load on your ROM-cartridges?
SHAOS wrote 01/13/2017 at 10:56 point
For now it's "Hello, World" and copies of existing cartridges
For future it will be arbitrary COM or EXE files and may be even DOS itself :)
Eric Hertz wrote 01/13/2017 at 11:08 point
Cool. The Disk Operating System, without a disk :)
Ah hah! I see the "Hello Hackaday!" update. Awesome!
Yann Guidon / YGDES wrote 01/13/2017 at 13:15 point
I think that some computers had MSDOS in firmware... Tandy maybe ?
SHAOS wrote 01/13/2017 at 16:23 point
And may be I'll try to put some PIC16 with PSP into cartridge to test is as co-processor ;)
Eric Hertz wrote 01/13/2017 at 17:28 point
@Yann Guidon / YGDES, I think I've read the same, recently. Another was one of the PSION devices(?). Still the concept is funny.
@Shaos got me thinking... these cartridges don't appear to toggle /OE (so I guess it's just assumed with /CS). OTOH, at the ROM-level, there might be nothing preventing you from requesting a "write" to one of these addresses, you just wouldn't get the /WE signal (for e.g. an SRAM or I/O device)... so map a certain range of addresses for write-only? (I guess, assuming the data-lines aren't buffered)
SHAOS wrote 01/13/2017 at 18:04 point
@esot.eric my idea to emulate write is to read from range 0x7FXX where XX is byte to write into PSP of the PIC (or to write into memory chip, but address should be set before that in similar fashion by reading from 0x7Exx and 0x7Dxx) - something like that :)
Eric Hertz wrote 01/13/2017 at 22:28 point
@Shaos Ah hah! That method would be immune to unidirectional data-buffers, as well!
