So cartridges in PCjr are actually PC BIOS extensions with 055h 0AAh in the beginning and this is how they checked on boot:
with step 2K it's looking for 0x55 0xAA signature and then check CRC:
And this piece shows how BIOS determines which algorithm to use - CRC16 or simple arithmetic sum:
So in order to create proper BIOS extension I wrote CRC16 library compatible with IBM's CRC_CHECK (see here) and special program that creates ROM image from COM-file (for now it has to be specifically created "read-only" COM-file) and put CRC at the end of that ROM image - PCJRCART.C
And this is my 1st program (pictured as title image of the project):
org 100h
section .text
start:
MOV BH,7 ; 0 for DOSBox
MOV BL,4
MOV CX,1
MOV DH,18
MOV DL,0
LEA SI,[STRI]
NEXT: MOV AH,2
INT 10H
INC DX
MOV AL,[SI]
CMP AL,'$'
JE KON
MOV AH,9
INT 10H
INC SI
JMP SHORT NEXT
KON: JMP KON
section .data
STRI DB 'Hello, Hackaday ! $'
Program is compilable by this command (you need NASM):
nasm test1.asm -fbin -o test1.com
now it could be tested in DOSBox for example or from DOS prompt on real machine and then pcjrcart test1.com to produce test1.bin that could be directly written into AT28C256 (or AT28C64 if size<=8K)
UPDATE: This approach (with some tweaks) was successfully used for PC XT machine by @esot.eric :)
https://hackaday.io/project/18868-improbable-secret-project/log/51957-we-have-a-bios-extension
SHAOS
FYI, found out the hard way... PCjr's method for verifying the BIOS extension is different than PC/XT's (which just uses a checksum, rather'n a CRC) :)
This is handy, either way... I've got my .COM running!
Excellent :)
I added another photocopy of the Tech Reference above to show how everything is working together - PCjr BIOS checks CRC16 for adresses above D0000 and simple sum below D0000:
https://cdn.hackaday.io/images/2168391484526882855.jpg
And yes, now I have paper version of "PCjr Technical Reference" (bought as "brand new") with SCHEMATICS!!! :)
Awesome!
I see, now the test you're talking about... I'll have to look more thoroughly at the XT code, as it does seem to treat "rom" as differently from "ros" (whatever that is).
It's funny, about 6 months ago I sold a PCjr that'd been sitting around in my storage for decades, even had the paper techref, but didn't look into it thoroughly enough to realize it had that level of detail. I thought it just talked about how to install floppy drives, printers, etc. But I never really used the PCjr, it was given to me after I'd gotten used to my PC/XT (from a garage sale with *boxes* of stuff for $20!).
@esot.eric Do you have some leftover by the way from that PCjr? As software, cables, extension boards, mice etc? :)
@Shaos well, now I wish I did... Would you believe it had two copies of the manual and some other docs... Was trying to recover space, so made sure *everything* went with it :/
Unbelievable :)
Was just browsing the XT's BIOS assembly-listing a few weeks ago... I find it utterly amazing they actually make that detailed info available, and the comments are so thorough!
Is it too early in the process to ask what you plan to load on your ROM-cartridges?
For now it's "Hello, World" and copies of existing cartridges
For future it will be arbitrary COM or EXE files and may be even DOS itself :)
Cool. The Disk Operating System, without a disk :)
Ah hah! I see the "Hello Hackaday!" update. Awesome!
I think that some computers had MSDOS in firmware... Tandy maybe ?
And may be I'll try to put some PIC16 with PSP into cartridge to test is as co-processor ;)
@Yann Guidon / YGDES, I think I've read the same, recently. Another was one of the PSION devices(?). Still the concept is funny.
@Shaos got me thinking... these cartridges don't appear to toggle /OE (so I guess it's just assumed with /CS). OTOH, at the ROM-level, there might be nothing preventing you from requesting a "write" to one of these addresses, you just wouldn't get the /WE signal (for e.g. an SRAM or I/O device)... so map a certain range of addresses for write-only? (I guess, assuming the data-lines aren't buffered)
@esot.eric my idea to emulate write is to read from range 0x7FXX where XX is byte to write into PSP of the PIC (or to write into memory chip, but address should be set before that in similar fashion by reading from 0x7Exx and 0x7Dxx) - something like that :)
@Shaos Ah hah! That method would be immune to unidirectional data-buffers, as well!
