Magical Runtime
07/15/2023 at 18:11 • 1 commentA couple days into our trip I had free time and finished assembling everything into the case and started runtime test.
Observations:- Form factor is a little weird due to the cell shape & size.
- Brightness is plenty to see by in the dark - brighter than I'd like actually, I ended up putting it under the table pointed at the wall.
- Not quite as bright as a flashlight though
After 72 hours of continuous run I went back to check my math. It turns out I mis-read/mis-remembered the cell capacity and it's 13.3Wh, not 3.7Wh, which means I should have about nine days of runtime with the current ~17mA configuration. I guess it meets original design requirements.Future thoughts:
- Multiple brightness modes could be useful, at least for nightlight/working light levels
- It needs better physical design for light modes
- Nightlight - anti-glare/down-light
- Table/general - diffusion, also anti-glare
- Flashlight - no diffusion, able to pick up and hold directionally
I'm not sure if all of those can be done well at the same time or not but it's percolating.
Initial Build
07/14/2023 at 01:51 • 0 commentsParts were collected, and bodged together. I did this all the week before going camping for a week - I figured that would be a good test.
Initial math told me with a 3.7Wh cell I should get 48hr runtime if I use less than 20mA, so I used a 220ohm resistor. This gives ~17ma at 3.7V nominal for the cell.
I whipped up a quick 3d printed clamshell prototype, charged it up, and went on vacation.
