Soldering this board is fairly easy.
Assembly of the weather station has now started and seems promizing!
As explained in the schematics part I discoverd "power management" issues... These issues have been fixed on the version 2 of this board
Version 2 of this board
This is the latest version. If you order the PCB will get it (previoud version are no longer available)
This PCB has been sponsored by PCBWay. Thanks for this !
You can order them here : WeatherStation @PCBWay
