Advantages of Training Reflexes
Training reflexes offers a series of advantages and benefits in both daily life and various sports fields. Some of the most notable advantages are as follows:
- Improved coordination: Training reflexes strengthens the connection between the brain and muscles, resulting in more precise and rapid movements in various physical and sports activities.
- Faster reaction speed: Trained reflexes enable the body to react more quickly to unexpected stimuli or situations. This is particularly useful in fast-reacting sports such as tennis, boxing, or soccer, where a swift response can make a difference.
- Increased personal safety: By improving reflexes, individuals can react more efficiently to dangerous or accident-prone situations. This can be crucial in everyday activities like driving or navigating crowded areas.
- Reduced risk of injuries: Quick and accurate reflexes help protect the body by responding appropriately to sudden movements or risky situations. This reduces the chances of muscular or joint injuries and falls.
- Cognitive stimulation: Reflex training challenges the brain and keeps it active. This can have broader cognitive benefits such as improved attention, concentration, and overall mental agility.
- Enhanced sports performance: In sports that require fast movements and instant reactions, such as tennis, basketball, or soccer, training reflexes can significantly impact performance. Athletes with well-developed reflexes have a competitive edge as they can anticipate and respond quickly to their opponents' actions.
In summary, training reflexes offers benefits ranging from improved coordination and reaction speed to increased personal safety and sports performance. Additionally, it stimulates the brain and can contribute to better overall cognitive functioning.
It's frequently used by e-gamers and marial artists. Following a video featuring Vasyl Lomachenko using one of these devices.
How Does It Work?
During the training session, the system guides you through the exercises with visual cues, audio prompts, and interactive challenges. It measures your response time and accuracy, providing real-time feedback on your performance. This feedback helps you track your progress and identify areas for improvement.
If connected to a PC, the system can keep a record of your training progress, including your reaction times, accuracy, and overall performance. This allows you to monitor your improvements over time and stay motivated to continue training.
By regularly engaging in reflex training sessions and progressively challenging yourself, you can experience significant improvements in your reflexes, coordination, and reaction speed.
A Quick Reference is available (in Spanish):
Cobra v1.2 - Guia Rapida v1.pdf
Power On
To power it on, you just need to connect the USB cable to a power supply. After a welcome screen, the Training Menu appears.
Menu
The Training Menu allows you to select different exercises and customize your training session. You can choose from a variety of reflex training exercises, such as reaction time drills, hand-eye coordination tasks, or simulated sports scenarios.
Once you've chosen an exercise, you can customize its difficulty level and duration based on your preferences and training goals. The system provides options to adjust the speed, complexity, and intensity of the exercises to challenge your reflexes effectively.
The currently selected option is displayed with the cursor: =>
You can change the option using the lit-up pads:
- Red: Up
- Green: Down
- Blue: Enter the selected option.
Training Modes
Reaction
A randomly lit red pad will start flashing. You must press it as quickly as possible. There is a random waiting time between each press and the next pad lighting up.
The screen displays the repetition number, reaction time, and statistics (maximum, minimum, and average reaction times of the series).
Continuous
Similar to the Reaction mode,...
Estudio Roble
jurc192
Michele Perla
Tauno Erik
