e accent aigu, é, - big red button
Sometimes you just need a button for a letter with an accent
0 followers
Learning French can be a touch frustrating on a regular English keyboard - so why not make it like a video game? Using a raspberry pi pico, circuit python, and a big video game button, you can get é anytime you want!
Start with a raspberry pi pico.
Install CircuitPython.
Copy in the adafruit_hid folder into the lib directory on the pico.
Create the main.py file in the main directory of the pico.
Attach the video game button to pin 1 (i.e., GPIO0) of the pico and pin 3 (GND). I did not use the LED of the video game button for this project.
Press the video game button, and get the é.
circuit_python_keyboard_french_main.py
py - 1.56 kB - 06/25/2023 at 17:29
Download
  • 1 × Raspberry Pi Pico
  • 1 × Adafruit Arcade Button
  • main.py
    sciencedude199006/25/2023 at 17:37 0 comments
    # Imports
    import usb_hid
    from adafruit_hid.keyboard import Keyboard
    from adafruit_hid.keycode import Keycode
    import digitalio
    import time
    import board
    # Make a keyboard
    kbd = Keyboard(usb_hid.devices)
    # The big red button
    btn_red = digitalio.DigitalInOut(board.GP0)
    btn_red.direction = digitalio.Direction.INPUT
    btn_red.pull = digitalio.Pull.UP
    # State variable
    keydown = 1
    # Loop forever
    while True:
        if btn_red.value == 1:
            print("1")
            # Set the state variable back to 1
            keydown = 1
        else:
            print("0")
            # Only if the state variable is 1, press the keys (stops rapidly keying)
            if keydown == 1:
                # Press and hold the LEFT ALT
                kbd.press(Keycode.LEFT_ALT)
                # Press and release keypad 0
                kbd.press(Keycode.KEYPAD_ZERO)
                kbd.release(Keycode.KEYPAD_ZERO)
                # Press and release keypad 2
                kbd.press(Keycode.KEYPAD_TWO)
                kbd.release(Keycode.KEYPAD_TWO)
                # Press and release keypad 3
                kbd.press(Keycode.KEYPAD_THREE)
                kbd.release(Keycode.KEYPAD_THREE)
                # Release all keys
                kbd.release_all()
            keydown = 0
        # Sleep for a bit
        time.sleep(0.03)
  • Special Key Codes
    sciencedude199006/25/2023 at 17:34 0 comments
    In the code, I wanted e accent aigu, but you could use any of the codes you want, or add more buttons!
    Alt+0233 (é)
    Alt+0224 (à)
    Alt+0232 (è)
    Alt+0249 (ù)
    Alt+0226 (â)
    Alt+0234 (ê)
    Alt+0238 (î)
    Alt+0244 (ô)
    Alt+0251 (û)
    Alt+0235 (ë)
    Alt+0239 (ï)
    Alt+0252 (ü)
    Alt+0231 (ç)
    The magic is that you have to "press" and "release" the KEYPAD numbers after the ALT key has been pressed, then release all the keys, i.e.,
    # Release all keys
    kbd.release_all()
View all 2 project logs
