main.py
06/25/2023 at 17:37 • 0 comments# Imports import usb_hid from adafruit_hid.keyboard import Keyboard from adafruit_hid.keycode import Keycode import digitalio import time import board # Make a keyboard kbd = Keyboard(usb_hid.devices) # The big red button btn_red = digitalio.DigitalInOut(board.GP0) btn_red.direction = digitalio.Direction.INPUT btn_red.pull = digitalio.Pull.UP # State variable keydown = 1 # Loop forever while True: if btn_red.value == 1: print("1") # Set the state variable back to 1 keydown = 1 else: print("0") # Only if the state variable is 1, press the keys (stops rapidly keying) if keydown == 1: # Press and hold the LEFT ALT kbd.press(Keycode.LEFT_ALT) # Press and release keypad 0 kbd.press(Keycode.KEYPAD_ZERO) kbd.release(Keycode.KEYPAD_ZERO) # Press and release keypad 2 kbd.press(Keycode.KEYPAD_TWO) kbd.release(Keycode.KEYPAD_TWO) # Press and release keypad 3 kbd.press(Keycode.KEYPAD_THREE) kbd.release(Keycode.KEYPAD_THREE) # Press and release keypad 3 kbd.press(Keycode.KEYPAD_THREE) kbd.release(Keycode.KEYPAD_THREE) # Release all keys kbd.release_all() # Set the state variable keydown = 0 # Sleep for a bit time.sleep(0.03)
Special Key Codes
06/25/2023 at 17:34 • 0 commentsIn the code, I wanted e accent aigu, but you could use any of the codes you want, or add more buttons!
Alt+0233 (é)
Alt+0224 (à)
Alt+0232 (è)
Alt+0249 (ù)
Alt+0226 (â)
Alt+0234 (ê)
Alt+0238 (î)
Alt+0244 (ô)
Alt+0251 (û)
Alt+0235 (ë)
Alt+0239 (ï)
Alt+0252 (ü)
Alt+0231 (ç)The magic is that you have to "press" and "release" the KEYPAD numbers after the ALT key has been pressed, then release all the keys, i.e.,
