First Test of the Mechanisim
Final Test with the new pendant and mode settings
I have repaired and hacked more than a few Sybian's over the last few years and decided it was time to design and build my own.
Vibrating Saddle Assembly Drawing v1.pdfAssembly DetailsAdobe Portable Document Format - 440.72 kB - 12/29/2016 at 22:12 |
CamShaftandPulley.pdfDetails on the Camshaft and PullieAdobe Portable Document Format - 290.33 kB - 12/29/2016 at 22:10 |
IMG_2383[1].JPGThe Finished Item, assembled and ready to go.JPEG Image - 2.22 MB - 12/29/2016 at 22:00 |
Just about all the 3D design was done in Fusion 360.
I hope this project hasn't been abandoned and the STL files lost.
https://cults3d.com/en/3d-model/naughties/vibrating-saddle
hello, can someone please explain how the motion and power gets transferred here to me ? I just see a shaft and multiple bearings so i Dont see how anything of the upper Bart would move. Is there a execntric Part i an missing ?
On the left (in the first picture) you can see a smaller pulley (brass) and that connects to the larger 3D printed pulley on the left of the motor I excluded the belt in the picture.
I made my one up. well have actually made a few now using a lathe and a spacer to offset the shaft ends. I have heard of a few people fabricating it using bolts but never heard back as to how well this worked.
Greg Zumwalt
SelfCAD
it's possible view the video?
