1Step 1
Install avrdude. The simplest way to do this is to install the Arduino software and execute it out of the c:\Program Files (x86)\Arduino\hardware\tools\avr\bin\ directory (or the equivalent is on your platform).
2Step 2
Install Atmel Studio 7 (optional). avra should also work. These tools are only needed if you want do change the code. Both products are free downloads.
3Step 3
Open the real\boom.atsln solution in Atmel Studio and build it or assemble main.asm if using avra.
4Step 4
Execute the burn.cmd script to copy the built binary onto your Arduino.
Jim Shortz
