1Purchasing Satellite Dish
For making Solar Genius I Purchase Satellite Dish in RS in PKR 2500 = 8.7 USD
2Purchasing Large Mirror
I Purchase a mirror 1.8 Meter x 1.8 Meter. Then Cut it in Circle with mirror cutter . Where the Dia of Mirror Was 1.8 Meter. Then Again cut it in small pieces 1x1 inch was each. Also giving them a unique number . How I Do it ? You can see the video. The cost of mirror with cutting into pieces 1x1 inch RS PKR 4500 = 15.7 USD
3Making Base For Cooker
Base is very important. It should be strong because all weight will take. you see in the video how we made it, all sides 24 inch length. Only pipe has 7.8 inch length.
After welding results and measurement
4Control Unit For Solar Cooker
With this We can change the direction in any side to find the right focal point. you can see in video and picture. How is Our control unit of solar cooker.
5​Mirror Fixing on Solar Cooker
6Fixing Stand With Parabolic Dish
7Why Use of Black Glasses ?
When using a parabolic solar cooker, it is recommended to wear black glasses or sunglasses for eye protection. The reason behind this is the intense concentration of sunlight that the parabolic reflector creates. The reflector directs and focuses sunlight onto a central point, which can result in extremely high temperatures.
Wearing black glasses helps to reduce the intensity of the sunlight entering your eyes, preventing potential damage caused by the concentrated heat and brightness. The dark lenses of the glasses act as a filter, reducing the amount of UV radiation and infrared rays that reach your eyes.
By wearing black glasses, you can ensure that your eyes are shielded from the intense light and heat generated by the parabolic solar cooker, providing a safer and more comfortable cooking experience. It is important to prioritize eye safety when working with concentrated solar energy
8Why use black pain on the concertation area
The use of black paint on the concentration area of a parabolic cooker serves a specific purpose: to maximize the absorption of sunlight and optimize heat generation. Black surfaces have high absorbance properties, meaning they can absorb a significant amount of solar radiation.
By painting the concentration area of the parabolic cooker with black paint, the surface becomes more effective at absorbing the incoming sunlight. This helps to enhance the conversion of solar energy into heat. The black paint absorbs a larger portion of the sunlight's energy spectrum, including visible and infrared light, which contributes to raising the temperature at the focal point of the cooker.
In contrast, lighter or reflective surfaces would reflect more sunlight, resulting in reduced heat generation. Therefore, the use of black paint ensures that the parabolic cooker can efficiently capture and convert solar energy into the intense heat required for cooking. It is a practical way to optimize the performance of the cooker and enhance its overall efficiency
9Removing permanent marker numbers
You know that we have give a unique number of every piece of mirror with permanent marker. For using the cooker we will clean with petrol to remove the every number. We will wet the cloth with petrol and clean with a cloth the mirrors of marker numbers.
10How to keep protected your solar cooker
It is very important to keep your solar cooker protected from dust. After using the cooker cover the cooker with a cloth with a cloth that will give you a long-life of your solar cooker. Also will give the best result of cooking. Clean your cooker with a soft cloth before using the cooker
Wasim Sahu
