Case Pictures
07/04/2023 at 19:30 • 0 commentsSome Case Pictures
Measuring Current with Clamp Adapter
07/04/2023 at 18:38 • 0 commentsToday a Clamp Adapter for 15A was in the mailbag.
Time for starting some first Measurements
AC Adapter for 230V Usage
07/04/2023 at 18:36 • 0 commentsThe 230V Adapter has arrived and I am currently soldering it.
Once done I will start testing and try to make the solution more secure.
Currently I am still missing the Relais component for Operation.![]()
Tap Detection with the GYRO
07/03/2023 at 19:42 • 0 commentsA couple of day ago I made a tap detection with the Gyro.
So far looks promising for usability without buttons.
You may have a look on the videos in the links to see operation
Ulrich
