Hackaday.io Hackaday.io
Sign up Log in
PH & Temperature Sensor to monitoring Hydroponics
Sensor platform for monitoring PH, Temperature, 02 absorption, and conductivity for Hydroponics Systems
brian-whartonBrian Wharton
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
23.8k views
9 comments
155 followers
  • Description
  • Details
  • Files 0
  • Components 6
    • View all
  • Logs 3
    • View all
  • Instructions 0
  • Discussion 9
View Gallery
23.8k
9
155
34
Team (2)
  • brian-whartonBrian Wharton
  • wicusWicus
Join this project's team
  • Blog post on initial test
  • Video of test in action
hardware
ongoing project
ESP8266 iot hydroponics
This project was created on 12/30/2016 and last updated 10 years ago.
Description
I created a PH and Temperature sensor to use for my hydroponics system. This is right now streaming back to io.adafruit.com.
Right now, the platform handles PH, air temperature, and water temperature. The goal is to add O2 absorption and conductivity. As well as stream the data to an Azure IoT Hub. That hub will then be able to store certain data in data storage, trigger events, etc.
Components
  • 1 × NodeMcu ESP8266 ESP-12E WIFI Development Board
  • 1 × DS18B20 Temperature Sensor (water proof for H2O temperature readings)
  • 1 × DS18B20 temperature sensor that is going to be soldered to the project board for airtemp
  • 1 × ADS1115 16bit ADC to convert the analog signal from the PH sensor to digital
  • 1 × DC to DC voltage converter to handle the required 5v for the PH sensor (the ESP8266 is 3.3v)
View all 6 components
Project Logs
Collapse
  • PH/Temperature sensor platform now in the garden
    Brian Wharton • 01/10/2017 at 22:12 • 0 comments
    Now have the sensor platform out in the garden. I used the following components to get things weatherproof and run power.
    1. Weatherproof indoor/outdoor box to hold my sensor platform and power
    2. 1' power cord extensions to make it easy to plug in "wall wort" for microcontroller power
    3. Power stake to split extension so that I can run pump and sensor platform
    Here is the inside of the box
    Here it is hooked up to the hydroponics tower structure. I am not happy with the organization. I think I will want to mount it to the tower structure. but right now, it works.
    I have more information on my blog here: https://catalinatechnology.wordpress.com/2017/01/10/phtemp-meter-now-in-the-garden/
  • Figured out my problem
    Brian Wharton • 01/05/2017 at 22:24 • 0 comments
    I was getting an invalid voltage reading on the ADC converter. and after tracing all my soldering, I realized that I connected to the wrong Analog pin. Dolt!!! Anyway, now everything working great.
    Next steps, adding Dissolved O2 sensor and switch out to post data to Azure IoT hub.
    new pic below:
  • Cleaned up my prototype a bit
    Brian Wharton • 01/05/2017 at 14:59 • 0 comments
    Cleaned up my prototype a bit by moving it off the breadboard and soldered to a smaller perf board. Also added some screw down terminals to connect the external sensors.
    One problem is that now the PH sensor is always reading a PH of about 2.5. Either I have something wrong in the wiring (I dont think so), or the probe went bad. I heard that these probes can be a bit weird. I am going to try to attach to a Leonardo Arduino and see if I get different results there. (ie. bypass my ADC converter and just read the analog directly on a real arduino).
    The results of the build are below. More to come later.
View all 3 project logs
Log In/Sign up to comment
Sign up with Github
OR
ric76 wrote 03/22/2020 at 19:56 • point
Hi, is it possible to have the code please?Thank you
Mateus wrote 05/07/2019 at 19:30 • point
I'm just wondering if it would work for long time if used 24/7 underwater, did you already tested?
ilucaphone wrote 11/23/2018 at 08:47 • point
hi! thanks for sharing your project! where ui can find sketch code?
seidenadler wrote 05/10/2018 at 17:05 • point
Hi Brian,
the hardware is now in my hand.
Unfortunately, i clound not find the software :(
Please send me the link
many thanks
Werner
AVR wrote 01/04/2017 at 02:41 • point
great minds think a like LOL
The Hydro part
https://hackaday.io/project/2964-hydropwnics
The sensing part
https://hackaday.io/project/10457-sunleaf
I'm going to be doing the pH after the next iteration of the sunleaf sensing platform.
zakqwy wrote 12/30/2016 at 15:37 • point
Can you give a bit more info on the pH sensor? They tend to be rather finicky and need regular calibration.
Brian Wharton wrote 12/30/2016 at 16:56 • point
I haven't been using it for long.  I have tried in 2 different environments (freshwater hydroponics tank and a saltwater fish holding pen in a marina), and tested against a stand-alone PH meter, and it is working pretty well.  What I did is an initial test with a PH calibration solution and then did an offset based on what my readings were.  the meter was slightly off, so I did an offset to handle it (see below)
  #define Offset -0.03            //deviation compensate
then in my loop(){}, I did this (where I added the Offset value to my final pHValue).
   static float pHValue, voltage;
   int16_t adc0;
   adc0 = ads.readADC_SingleEnded(0);
   voltage = (adc0 * 0.1875) / 1000;
   pHValue = 3.5*voltage + Offset;
What I am going to end up doing is being able to have a calibration mode that I can put the device into (pressing a button), and then place the device into the calibration solution, which will then update the Offset and store in non-volatile memory.  I figure that I would do this every week or so to keep it in calibration.
zakqwy wrote 12/30/2016 at 17:02 • point
sounds good. pH sensors should be kept wet, either in the solution you're measuring or in 3M KCl. they also gradually age and lose sensitivity, so keep an eye on the slope in addition to the offset value; once the slope drops to 90% or so of its original value the probe is probably no longer reliable. Best way to get a good idea of slope is to do _two_ calibrations at different pH levels that bound your expected measurement range, such as 4.0 and 7.0.
Brian Wharton wrote 12/30/2016 at 17:06 • point
Good advice on the continuing of testing.  I keep my standalone PH sensor always in solution when I am not using it and recalibrate every few months.
On this particular sensor, it is going to be submerged 100% of its lifespan.  Others have noted that this PH sensor is good for about 6 months.  I am going to be using it in two different environments (freshwater for hydroponics and saltwater for Aquaculture).  The saltwater is going to be a bit more harsh, so I figure that I am going to give it about 4 months of lifespan before replacing.  That isn't terrible since having 1,000 fish floating on the surface, because the PH became toxic for them, is much worse than replacing a $40 sensor every few months.
This Portenta things have become like an addiction here I post a new project where I used a thermocouple sensor through my Arduino Portenta.
Project Owner Contributor
Portenta and Thermocouple Sensor (with MAX6675)
diy-guy-chrisDIY GUY Chris
This small Si7021 fully compatible with Arduino and works on I2C interface. Has a better resolution and measuring ability than DHT.
Si7021 based Temperature and Humidity sensor
electroboyElectroBoy
The 2017 Hackaday Prize
Implement a PM 2.5 sensor with Internet and Twitter connectivity to track air quality with a low cost device.
Low cost Air Quality sensor
valenciacavalencia.ca
Testing temperature, pressure, and flow sensors using an Arduino Uno
FSAE Temperature, Pressure, and Flow Sensor Tests
braxton-leeBraxton Lee
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "PH & Temperature Sensor to monitoring Hydroponics", please tell us the reason.
Send message
Remove Member
