1Basic Build
Instructions for this device are rather simple. Connect GND, +5V and analog signals from the sensor to the respective ones in the ESP8266 (The D1 Mini only has one analog input A0). Then replace the SSID details along with the bot token and chat id to send the messages to in the EKO-Telegram-Simple.ino. Fire it up and it will start monitoring your plants!
Augusto
