Attiny85 Uploader
With this shield for Arduino UNO it is possible to program the famous Attiny85 microcontroller both in DIP and SOP.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Attiny85 Uploader
The shield has a socket for programming the DIP format and a clamp for the SOP format, on board there are three LEDs: Power, Programming and Error. In addition there is a 4-pin connector connected to 5V, D3, D4 and GND.
- Just load the ArduinoISP sketch that you find in the Examples section into an Arduino UNO
- Now go to Settings and add the following URL in the space provided:
https://raw.githubusercontent.com/damellis/attiny/ide-1.6.x-boards-
manager/package_damellis_attiny_index.json
- From the Board Manager search for "Attiny" and install the files.
- From the Tools menu select the Attiny25/45/85 board.
- Now you will have to write the bootloader from the Tools menu and clicking on Write the
bootloader
- Once this is done you just have to upload your sketch from the Sketch menu by clicking on
Upload via programmer
