Remove the stuffing from the plushie and set aside.
3
Push LEDs through
Push each LED through the corresponding square on the top of the plushie. Be sure to support the LED legs when pushing through so they don't bend. Make sure that all LEDs are facing the same direction. Once all LEDs are through, turn the plushie inside out.
