cncjogger2_main.ino
Code for the feedback-based CNC-Spindle speed control shown in Video 7 of the series.
ino -
4.47 kB -
05/05/2025 at 19:39
Download
breakout_board.kicad_sch
The Arduino UNO Breakout board as KiCad Schematics
x-kicad-schematic -
158.89 kB -
06/16/2024 at 05:48
Download
analogPushbuttons.cpp
.cpp of the library.
x-c++src -
2.28 kB -
02/01/2024 at 14:26
Download
analogPushbuttons.h
Library for reading push buttons connected to the analog port. The push buttons must be connected together via R2R-Ladder so that each buttonpress leads to a different voltage. Also suitable for reading a potentiometer that is used as discrete selector.
x-chdr -
1.26 kB -
02/01/2024 at 14:26
Download
TEST__rpm_counter_with_LED_display.ino
Test-program to count the motor RPM. The program counts how often a pin goes from Low to High in 180ms and writes the corresponding RPM value to a LED display.
ino -
1.74 kB -
02/01/2024 at 09:20
Download
TEST__pwm_spindle_control.ino
More complex version of the program "TEST__rpm_counter_with_LED_display.ino ": Here, spindle speed control via PWM is added, and the target speed is read off a pot connected to the analog port.
ino -
4.77 kB -
02/01/2024 at 09:20
Download
