Machines and tools
07/26/2023 at 12:47 • 0 comments- Drilling machines - Drill bit 6mm and Hole saw (3 in)
- Small grinding machines
- Metal file
- Scissors/Cutter
Maintenance
07/26/2023 at 11:51 • 0 commentsWeekly Care
- Check for clogs, leaks, or any visible damage.
- Regularly monitor the water level in the reservoir to ensure that it doesn't run dry, especially during hot and dry periods.
- Check and adjust the nutrient levels regularly according to the plant's needs.
- Regularly monitor the plants to check for signs of overwatering or underwatering. Adjust the watering schedule accordingly.
Maintenance and Cleaning
- Thoroughly inspect all components and clean if necessary.
- Remove any debris, roots, or sediment that may accumulate in the pipes, wicking material, or the water reservoir.
- Use a mild detergent solution or vinegar to clean the PVC pipes and containers to prevent algae growth.
- Replace the wicking material if it becomes clogged or starts deteriorating to maintain efficient water delivery to the plants.
- Promptly fix any leaks, damaged pipes, or connectors to prevent water wastage and maintain a consistent water supply.
Friendly reminder: If you use the system outdoors and experience freezing temperatures, drain the water to prevent pipes from bursting.
