AutoDuct_PCB_BOMs.xlsx
Bill of material for all PCBs used in the project (Main control PCB, BLE daughter board, hall effect sensor board)
sheet - 31.05 kB - 10/10/2023 at 07:33
Download
AutoDuct Firmware.zip
source code for main firmware as well as bootloader including HEX files
x-zip-compressed - 662.49 kB - 10/09/2023 at 19:49
Download
AutoDuctMainboard_v1.1.brd
Eagle Board file for Mainboard PCB
brd - 212.67 kB - 10/09/2023 at 19:44
Download
AutoDuctMainboard_v1.1.sch
Eagle Schematic file for Mainboard PCB
sch - 1.48 MB - 10/09/2023 at 19:44
Download
BluetoothAdapter_v2.sch
Eagle Schematic file for BLE daughter board PCB
sch - 421.04 kB - 10/09/2023 at 19:44
Download
ThrustCollarSensorPCB_gerber.zip
Thrust Collar Hall Effect Sensor PCB manufacturing files (Gerber)
x-zip-compressed - 60.87 kB - 10/09/2023 at 19:44
Download
AutoDuctMainboard_v1.1_gerber.zip
Mainboard PCB manufacturing files (Gerber)
x-zip-compressed - 254.29 kB - 10/09/2023 at 19:44
Download
BluetoothAdapterv2_gerber.zip
BLE daughter board PCB manufacturing files (Gerber)
x-zip-compressed - 49.21 kB - 10/09/2023 at 19:44
Download
AutoDuctMainboard_v1.1.pdf
Main board schematics (PDF)
Adobe Portable Document Format - 102.42 kB - 10/09/2023 at 19:44
Preview
BluetoothAdapter_v2.brd
Eagle Board file for BLE daughter board PCB
brd - 51.76 kB - 10/09/2023 at 19:44
Download
BluetoothAdapter_v2.pdf
BLE daughter board schematics (PDF)
Adobe Portable Document Format - 39.77 kB - 10/09/2023 at 19:44
Preview
ThrustCollarSensorPCB.pdf
Thrust Collar Hall Effect Sensor PCB schematics (PDF)
Adobe Portable Document Format - 15.91 kB - 10/09/2023 at 19:44
Preview
VentAdapter.STL
Air duct adapter / outer shell of AutoDuct assembly
Standard Tesselated Geometry - 28.99 MB - 09/11/2023 at 20:02
Download
PistonSliderMod.STL
slider component of linear actuator with inner thread
Standard Tesselated Geometry - 24.56 MB - 09/11/2023 at 20:02
Download
FrontCap.STL
front cover / cap
Standard Tesselated Geometry - 13.32 MB - 09/11/2023 at 20:02
Download
Centralizer.STL
main body part of linear actuator
Standard Tesselated Geometry - 16.48 MB - 09/11/2023 at 20:02
Download
WingRing.STL
outer shell of AutoDuct unit with carrier ring for linear actuator. Cable guide channels integrated into two of the 3 wing structures.
Standard Tesselated Geometry - 16.55 MB - 09/11/2023 at 20:01
Download
ThrustRing.STL
axial thrust ring for linear actuator
Standard Tesselated Geometry - 986.80 kB - 09/11/2023 at 20:01
Download
VentCover.STL
front panel of AutoDuct assembly with mounting point for daughter PCB
Standard Tesselated Geometry - 1.14 MB - 09/11/2023 at 20:01
Download
ThrustCollar.STL
Standard Tesselated Geometry - 158.29 kB - 09/11/2023 at 20:01
Download
PistonTest.STL
shutter disc
Standard Tesselated Geometry - 8.09 MB - 09/11/2023 at 20:01
Download
SensorCover.STL
sensor cover for efficient air flow guidance
Standard Tesselated Geometry - 478.40 kB - 09/11/2023 at 20:01
Download
MotorCarrier.STL
motor carrier for linear actuator
Standard Tesselated Geometry - 1.79 MB - 09/11/2023 at 20:01
Download
SensorAlignmentTemplate.STL
alignment template used during assembly of sensor ring PCB
Standard Tesselated Geometry - 89.54 kB - 09/11/2023 at 20:01
Download
FlatCap.STL
back cover for main electronics
Standard Tesselated Geometry - 3.08 MB - 09/11/2023 at 20:01
Download
PCBassemblyTemplate.STL
template used for solder paste application of main control board
Standard Tesselated Geometry - 1.25 MB - 09/11/2023 at 20:01
Download
LeadScrew.STL
lead screw of linear actuator
Standard Tesselated Geometry - 8.69 MB - 09/11/2023 at 20:01
Download
FilterClamp.STL
snap clamp units to hold filter disc in place
Standard Tesselated Geometry - 52.82 kB - 09/11/2023 at 20:01
Download
MagnetCarrierLong.STL
adjustable magnet carrier for open end stop detection
Standard Tesselated Geometry - 8.48 kB - 09/11/2023 at 20:01
Download
MagnetCarrierShort.STL
adjustable magnet carrier for closed end stop detection
Download
