Hackaday.io Hackaday.io
Sign up Log in
PIC10F220 MIDI Controller
Contender for world's smallest? 6 pin chip supports 2 knobs and a button.
greg-kennedyGreg Kennedy
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.3k views
1 comments
30 followers
  • Description
  • Details
  • Files 0
  • Components 5
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 1
View Gallery
2.3k
1
30
9
Team (1)
  • greg-kennedyGreg Kennedy
Join this project's team
  • Homepage / Project Log
pic midi controller
This project was created on 02/25/2014 and last updated 13 years ago.
Description
I’ve been working sporadically on this tiny MIDI controller. It targets the smallest PIC microcontroller available with onboard A/D converter – the PIC10F220.
Currently it reads two potentiometers and a button input using three of the GPIO pins, and it bitbangs the remaining output pin to produce MIDI-Out at 31250hz using cycle-counted delays. Since practically everything is already on-chip, this thing could just be epoxied straight to the enclosure. There are only two or three more components – no PCB required!
This microcontroller sports a whopping 256 instructions and 16 bytes of RAM. Even so, the MIDI controller code consumes less than half the available resources after a modest amount of optimization for size. One might see this as my response to using a certain 32k ROM / 2k RAM microcontroller to blink some lights, but I won’t admit to being that petty.
Components
  • 1 × PIC10F220 Content/Electronic Components/Semiconductors and Integrated Circuits/Microprocessors, Microcontrollers, DSPs/ARM, RISC-Based Microcontrollers
  • 1 × SPST Momentary Pushbutton
  • 1 × MIDI connector (female)
  • 1 × 220ohm Resistor
  • 2 × Rotary Potentiometer - 10k Ohm, Linear
Project Logs
Collapse
  • Parts on the way...
    Greg Kennedy • 02/26/2014 at 15:23 • 0 comments
    Several eBay orders out, the most important being the PICKit3 clone.  About time I got the programmer : )​
View project log
Log In/Sign up to comment
Sign up with Github
OR
Gorky wrote 05/11/2015 at 12:24 • point
Were you able to complete the project?
I know exactly what you're thinking! "Why hasn't this been made sooner!?"
Project Owner Contributor
An Xbox controller but it's all analog sticks
solderkingSolderking
How to control the 7 LEDs of a die with only 2 GPIO - a miniaturized electronic die based on ATtiny10.
Dice10
timTim
adapter that allows one to use unmodded controller for NES and Famicom system
Neo Geo controller for Nintendo NES and Famicom
killuakillua
I added a joystick I got from a 360 controller to an NES controller with a few transistors and modification to the analog.
Adding an analog stick to an NES controller
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "PIC10F220 MIDI Controller", please tell us the reason.
Send message
Remove Member
