Hackaday.io Hackaday.io
Sign up Log in
PIC10F220 MIDI Controller
Contender for world's smallest? 6 pin chip supports 2 knobs and a button.
greg-kennedyGreg Kennedy
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.3k views
1 comments
30 followers
  • Description
  • Details
  • Files 0
  • Components 5
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 1
View Gallery
2.3k
1
30
9
Team (1)
  • greg-kennedyGreg Kennedy
Join this project's team
  • Homepage / Project Log
pic midi controller
This project was created on 02/25/2014 and last updated 13 years ago.
Description
I’ve been working sporadically on this tiny MIDI controller. It targets the smallest PIC microcontroller available with onboard A/D converter – the PIC10F220.
Currently it reads two potentiometers and a button input using three of the GPIO pins, and it bitbangs the remaining output pin to produce MIDI-Out at 31250hz using cycle-counted delays. Since practically everything is already on-chip, this thing could just be epoxied straight to the enclosure. There are only two or three more components – no PCB required!
This microcontroller sports a whopping 256 instructions and 16 bytes of RAM. Even so, the MIDI controller code consumes less than half the available resources after a modest amount of optimization for size. One might see this as my response to using a certain 32k ROM / 2k RAM microcontroller to blink some lights, but I won’t admit to being that petty.
Components
  • 1 × PIC10F220 Content/Electronic Components/Semiconductors and Integrated Circuits/Microprocessors, Microcontrollers, DSPs/ARM, RISC-Based Microcontrollers
  • 1 × SPST Momentary Pushbutton
  • 1 × MIDI connector (female)
  • 1 × 220ohm Resistor
  • 2 × Rotary Potentiometer - 10k Ohm, Linear
Project Logs
Collapse
  • Parts on the way...
    Greg Kennedy • 02/26/2014 at 15:23 • 0 comments
    Several eBay orders out, the most important being the PICKit3 clone.  About time I got the programmer : )​
View project log
Log In/Sign up to comment
Sign up with Github
OR
Gorky wrote 05/11/2015 at 12:24 • point
Were you able to complete the project?
Customisable USB adapter for arcade controls.
Project Owner Contributor
AVeRCADE
danjovicdanjovic
Using the beeper to play music, well almost music more of a tune really.
Smart Controller LCD 12864 making music.
films4youFilms4You
I know exactly what you're thinking! "Why hasn't this been made sooner!?"
An Xbox controller but it's all analog sticks
solderkingSolderking
adapter that allows one to use unmodded controller for NES and Famicom system
Neo Geo controller for Nintendo NES and Famicom
killuakillua
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "PIC10F220 MIDI Controller", please tell us the reason.
Send message
Remove Member
