The printing time for all parts was approx. 20 hours. I printed the case in two parts, so fewer supports were needed and the holes for the mouse buttons and trackpad etc. were printed without any problems. In addition, I couldn't print it out in one go with the Bambu X1C, the case has the dimensions 253x253x104mm and the Bambu actually has a build volume of 255x255x255mm. However, the bamboo has a small area in the XY movement which it cannot use because the filament cutter is located there. Interesting fact, but didn't help me that much.
