Does it run DOOM without throttling?
08/16/2023 at 18:28 • 0 commentsWhether DOOM runs on a Raspberry Pi 4 is almost a boring question, but it is enough to show how well the cooling and the power supply for the devices in the case are.
Last project log entry: Demo videos
08/13/2023 at 15:08 • 0 commentsAs can be seen in the demo videos, Raspbian does not run as efficiently as kali linux. I will probably use kali linux despite the many packages that need to be updated.
Taskbar TOP: Kali Linux
Taskbar BOTTOM: Raspbian -
Perfect the brightness of the LEDs
08/11/2023 at 15:29 • 0 commentsAt the beginning I took two 500ohm resistors, the red LED was much too bright and the orange hardly recognizable. Now the orange LED has a series resistance of 50 Ω and the red 1 kΩ.
orange is the ACT LED of the raspberry and red is POWER (just like the LEDs on the Raspberry pi board) -
Installing OS, configure ACT LED and Powerbutton
08/10/2023 at 14:16 • 0 commentsSince I have external access to the raspberry microSD, I don't have to make a final decision on an OS. I am currently testing whether raspbian (32bit) meets all my requirements. I have already created a kali linux microSD and adapted the OS installation to the cyberdeck, kali linux only has the disadvantage for me that it contains a lot of packages which all have to be updated...
Power LED now works correctly ![]()
cool-retro-term (is the name of the apt package) ;-) ![]()
The most important thing I have to configure with a new OS is the display -
Assembly complete
08/06/2023 at 18:43 • 0 comments![]()
Code the "peripherals Arduino"
08/02/2023 at 21:07 • 0 commentsI noticed that it's not that easy to write the firmware for the trackball myself, my version was pretty sticky, but it worked. However, that was enough for me to understand the function. Then I have to look for a clever library on the internet, but unfortunately I didn't find any library, but the following brilliant demo code:
https://github.com/LSChyi/blackberry-mini-trackball
The trackball works super smooth now. The rotary encoder with the button and the two mouse buttons were then written fairly quickly.
I will upload the arduino code, all STL's of the case, bash scripts etc. here at the end of the project (hopefully before the cyberdeck contest deadline).
serial output from finished arduino code demo of the peripherals arduino
prepare electronics
08/01/2023 at 19:13 • 0 comments![]()
raspberry wiring harness ![]()
peripheral wiring harness ![]()
prepare power and act LED ![]()
finished LED part ![]()
mousebuttons ![]()
mousebuttons (other view) ![]()
powerbutton -
Painting successful
07/31/2023 at 20:46 • 0 comments![]()
Painting failed
07/31/2023 at 12:35 • 0 commentsWhen coloring the case, everything that could go wrong went wrong. I bought a weird PU spray that splattered so particles and didn't cover at all (not even the gray primer). So sand and prime again.
prime: all good ![]()
Too much color because it didn't cover. Pretty sure my fault too, I'm just bad at painting. ![]()
so sand again (this "heavily used" look would look cool too) -
All parts printed and the visibile parts sanded
07/29/2023 at 13:46 • 0 comments![]()
All printed parts ![]()
All parts (without cables)
