Spacecraft Abort Handle
A 3D-printed abort handle based on the CST-100 cockpit and suitable for KSP
One of my ongoing projects is to build a set of immersive controls for Kerbal Space Program (on hackaday.io here: https://hackaday.io/project/183090-ksp-controller-hardware). This included an abort control, but just as a simple push button, which was pretty dull compared to the real-life versions.
This version is a rotate-to-activate switch that uses a spring-loaded cam that gives a satisfying feel, as well as a microswitch for a tactile click.
I've set this up as a seperate project as it has a very different set of parts and assembly process
abrt_base.stl
Standard Tesselated Geometry - 957.02 kB - 07/28/2023 at 07:05
Download
abrt_handle.stl
Standard Tesselated Geometry - 464.54 kB - 07/28/2023 at 07:05
Download
abrt_lid.stl
Standard Tesselated Geometry - 537.58 kB - 07/28/2023 at 07:05
Download
abrt_base_test.stl
Standard Tesselated Geometry - 355.16 kB - 07/28/2023 at 07:05
Download
abrt_inner_lid.stl
Standard Tesselated Geometry - 262.48 kB - 07/28/2023 at 07:05
Download
View all 7 files
View all 12 components
  • Prototype and Cam Mechanism
    Tobias08/08/2023 at 06:40 0 comments
    Here's a gif showing how the mechanism operates - essentially as the handle is turned the bearings run along a cam surface. The bearings are on a lever tensioned by the extension spring. The cam surface is designed so that the deflection of the lever is linear with the rotation of the handle - and so the resistance is linear. This also means that the handle rotates in both directions, and snaps back smoothly to the centre
View project log
  • 1
    Before Assembly
    Most of the assembly is covered in the video below, but there are a few things that need to be done first:
    1. Solder leads onto the microswitch
    2. Insert threaded inserts either with a soldering iron or with a press
  • 2
    Assembly
    This video covers all of the main steps of assembly:
    You might notice that I haven't installed all of the screws... turns out I ran out of threaded inserts
  • 3
    Complete!
    You'll now have a complete abort handle that acts as a simple switch. From here you can wire it up to an Arduino, Raspberry Pi, computer or really anything
View all 3 instructions
