1Before Assembly
Most of the assembly is covered in the video below, but there are a few things that need to be done first:
- Solder leads onto the microswitch
- Insert threaded inserts either with a soldering iron or with a press
2Assembly
This video covers all of the main steps of assembly:
You might notice that I haven't installed all of the screws... turns out I ran out of threaded inserts
3Complete!
You'll now have a complete abort handle that acts as a simple switch. From here you can wire it up to an Arduino, Raspberry Pi, computer or really anything
Tobias
