LoShark
The Ultra-Compact Powerhouse for LoRa Debugging and Connectivity
Next-gen USB LoRa debug tool. Runs mainline Linux on itself. Versatile JavaScript ES2015 interface allows access to every SX126x chip register easily. Up to 4GB flash storage allows long-time data collection. Works with any modern PC.
Introduction
The LoShark is a USB key-sized device, designed with a keen focus on offering robust LoRa connectivity and debugging capabilities. It's engineered to operate both independently and in conjunction with a PC, opening up a versatile range of use-cases.
Video demo:
The software and design files are available in our GitHub repo.
Interested in getting one? Please visit our store.
Key Features
Compact and Portable Design
Designed with a USB key form factor, LoShark can be easily plugged into a PC or operate independently when connected to a USB power bank. This design provides unparalleled convenience and portability. It also has a nice plastic enclosure.
▲ PCB of the LoShark. Our X1501 Pico SoM is near the USB port. The HJ-68LR SiP is near the SMA port.
▲ LoShark connected to a mini laptop. A perfect combo for outdoors LoRa testing.
JavaScript Programmability with Resonance
The LoShark's primary strength is its ability to execute JavaScript (ES2015) through our runtime, Resonance. It's still in alpha state, and it will be open sourced with a free software license soon later. You can join our Discord for alpha testing at this moment.
This feature enables users to program specific tasks, serving as a powerful tool for LoRa debugging, such as capturing packets and sending LoRa messages either manually or programmatically, at minimal delay.
▲ Demo JavaScript application for the LoShark
▲ Interacting with the Semtech SX126x chip directly in a NodeJS-like console
Linux Support
The LoShark runs mainline Linux, allowing users to write bare bone Linux applications in C and C++. It's possible to expand the device's capabilities far beyond its size with careful programming.
▲ Linux is running inside the LoShark
Memory and Storage
With 8MB of DRAM, 8MB of PSRAM, and additional flash storage starting from 128MB to a maximum of 4GB, LoShark packs a punch in memory capacity for its size. This is very useful for data collection tasks, such as logging every received LoRa packet, alongside with the signal status and time.
▲Transferring files between LoShark and PC is made easy with the MTP protocol
Energy Efficient
LoShark operates at a low power consumption of 150mW while plugged into a PC and not transmitting, making it an energy-efficient solution for your LoRa needs.
▲ Power consumption of the LoShark. It can be further reduced by turning off the bright RGB LED.
X1501 Pico SoM
Featuring our X1501 Pico System on Module (SoM), the LoShark is powered by a MIPS32r2 RISC processor, with a full-featured hardware FPU, enabling users to implement complex algorithms without worrying about performance, such as audio codecs like Codec2 and Opus, and software-based error correction codes such as DSSS and LDPC.
▲ LoShark is capable of encoding 320kbps stereo Opus audio at 2.5x realtime speed
Standard SMA Socket
LoShark uses a standard SMA-F socket for RF connectivity, allowing users to easily swap antennas or connect to a power amplifier.
▲ LoShark and different compatible antennas
Real-Time Clock
The device includes an RTC, holding time configurations for at least 2 days, perfect for configuring on a PC and then operating separately with a power bank.
Programmable RGB LED Indicator
The device includes a programmable RGB LED indicator accessible via I2C, providing visible feedback and status indications to the user.
▲ LoShark doing data collection to its internal flash storage while being powered by a power bank
PCB_LoShark L1_2023-07-29.pdf
Adobe Portable Document Format - 478.25 kB - 07/28/2023 at 23:32
Preview
SCH_LoShark L1_2023-07-29.pdf
Adobe Portable Document Format - 334.59 kB - 07/28/2023 at 23:32
Preview
  • 1 × SudoMaker X1501 Pico SoM
  • 1 × HJSIP HJ-68LR
  • 1 × EPSON RX8900CE
  • 1 × Lyontek LY68L6400SLIT
  • 1 × AWINIC AW2023DNR
  • The LoShark now has a nice web-based dashboard
    Reimu NotMoe02/09/2024 at 00:09 1 comment
    The LoShark now has a nice web-based dashboard for PC & Android. You can upgrade to latest firmware and visit su.mk/loshark-app to use it.
  • Some API changes
    Reimu NotMoe08/10/2023 at 23:35 0 comments
    After some careful thinking, I changed the JS API of Resonance a bit:
    • loadModule() now follows the naming convention of nodejs modules
    • Peripheral drivers are now split from the core of Resonance and moved to separate modules
    • Use Promise for async APIs where possible
    So now the LoShark example code looks likes this:
    // X1501 EVB
    const {SX126x} = loadModule("loshark/sx126x");
    const {GPIOControllerLinux} = loadModule("gpio/linux");
    const {SPIControllerLinux} = loadModule("spi/linux");
    const gpioa = new GPIOControllerLinux(0);
    const pa12 = gpioa.open(12, "SX126x NRST");
    const pa13 = gpioa.open(13, "SX126x DIO2");
    const pa14 = gpioa.open(14, "SX126x DIO1");
    const pa15 = gpioa.open(15, "SX126x BUSY");
    const spi0 = new SPIControllerLinux(0);
    const spidev0_3 = spi0.open(3);
    const cfg = {
      chip: "SX1268",
      tcxo: { voltage: 0x2, timeout: 32 },
      gpio: { reset: pa12, busy: pa15, dio1: pa14, dio2: pa13 },
      spi: spidev0_3,
    mdm = new SX126x(cfg);
    mdm.on("receive", msg => console.log("packet received:", msg));
    mdm.on("signal", sig => console.log("signal:", sig));
    mdm.on("event", ev => console.log("event:", ev));
    mdm.open().then(console.log("modem opened"));
    mdm.propertySet("modem0.modulation.lora.bw", 62).then(console.log);
    mdm.propertyList().then(console.log);
    mdm.transmit('Bonjour mes reufs').then(console.log);
    You can use the await keyword in async functions in .js files.
    Suggestions are welcomed.
  • LoShark DO run the mainline Linux kernel
    Reimu NotMoe08/02/2023 at 19:06 0 comments
    As of 2023-08-02, this comment appeared below the CNX software article. It appears to be from a upstream Linux maintainer.
    And here are my responses:
    • X1501 DO boot the latest 6.5-rc4 kernel using the X1000 target
    • It's not our fault as fixes & new drivers of the X1000/X1501 can't be mainlined
    • X1501 can't run systemd but it's still awesome with its 18mW standby power usage
    • A PSRAM is not a NOR flash
    LoShark (tested on X1501 EVB with LoShark's rootfs) running the latest rc kernel (with X1000 as target):
    This is the complete boot log. Many things are broken, as expected. But you get a working shell.
    X-Loader Build: 2023-06-28 - 19:08:31
    EPC: 0x80101c24
    stage2 inited
    uImage name: Linux-6.5.0-rc4-LoShark+
    uImage size: 1020740
    uImage load addr: 80100000
    uImage endpoint addr: 8030cff4
    Jumping to 8030cff4
    [    0.000000] Linux version 6.5.0-rc4-LoShark+ (root@Rinyuki-Laptop) (mipsel-linux-gnu-gcc (Ubuntu 9.4.0-1ubuntu1~20.04) 9.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #11 PREEMPT Thu Aug  3 04:13:47 CST 2023
    [    0.000000] CPU0 revision is: 2ed1024f (Ingenic XBurst)
    [    0.000000] FPU revision is: 00330000
    [    0.000000] MIPS: machine is YSH & ATIL General Board CU1000-Neo
    [    0.000000] earlycon: x1000_uart0 at MMIO 0x10032000 (options '115200n8')
    [    0.000000] printk: bootconsole [x1000_uart0] enabled
    [    0.000000] **********************************************************
    [    0.000000] **   NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE   **
    [    0.000000] **                                                      **
    [    0.000000] ** This system shows unhashed kernel memory addresses   **
    [    0.000000] ** via the console, logs, and other interfaces. This    **
    [    0.000000] ** might reduce the security of your system.            **
    [    0.000000] **                                                      **
    [    0.000000] ** If you see this message and you are not debugging    **
    [    0.000000] ** the kernel, report this immediately to your system   **
    [    0.000000] ** administrator!                                       **
    [    0.000000] **                                                      **
    [    0.000000] User-defined physical RAM map overwrite
    [    0.000000] Initrd not found or empty - disabling initrd
    [    0.000000] Primary instruction cache 16kB, VIVT, 4-way, linesize 32 bytes.
    [    0.000000] Primary data cache 16kB, 4-way, VIPT, no aliases, linesize 32 bytes
    [    0.000000] MIPS secondary cache 128kB, 4-way, linesize 128 bytes.
    [    0.000000] Zone ranges:
    [    0.000000]   Normal   [mem 0x0000000000000000-0x00000000007fffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000000000000-0x00000000007fffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000007fffff]
    [    0.000000] Kernel command line: console=ttyS2@115200n8 earlycon mem=8M@0x0 loglevel=7 devtmpfs.mount=1 clk_ignore_unused no_hash_pointers
    [    0.000000] Dentry cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
    [    0.000000] Built 1 zonelists, mobility grouping off.  Total pages: 2032
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] Memory: 4812K/8192K available (2122K kernel code, 141K rwdata, 220K rodata, 644K init, 86K bss, 3380K reserved, 0K cma-reserved)
    [    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
    [    0.000000] NR_IRQS: 256
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] clocksource: ingenic-ost: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1274173631191 ns
    [    0.000003] sched_clock: 32 bits at 1500kHz, resolution 666ns, wraps every 1431655764658ns
    [    0.008517] Calibrating delay loop... 1002.49 BogoMIPS (lpj=501248)
    [    0.022791] pid_max: default: 4096 minimum: 301
    [    0.033908] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
    [ 0.041296] Mountpoint-cache hash table entries: 1024 (order:...
View all 3 project logs
soni wrote 10/03/2024 at 16:10 point
Ok this device working with reticulum?  https://reticulum.network/manual/interfaces.html Please make a example
powiadam.ci wrote 03/18/2024 at 10:58 point
I found nice lib https://earthstar-project.org/docs/what-is-it meybe You  can use it for offline transfer file
e64 wrote 03/16/2024 at 12:29 point
In second rev.
a) Please add socket to screen. Not soldering screen but add socket or place for spi small cheap screen. The idea is not to increase the price of the device, but for those willing, you can add a screen simply by connecting the cables without soldering
b) Power. Adding a plug to connect LiPo would help make this device , a mobile device. When someone wants can buy a solar panel and charge Lipo using the already existing USB socket. Or if he wants he can buy a solar garden light with an 18650 cell and power the device that way (charging from usb).
c) 4 buttons
In a mesh network situation, a lot of nodes are needed. They don't need a computer, but they do need power. Adding lipo or 18650 would make it easier to install devices on rooftops, on antenna masts. Or simply as offgrid devices.At the same time, it would not make production too expensive. Adding only 4 buttons and plugs for battery installation and plugs for the screen will keep the price low and at the same time increase the distance of network coverage.
meybe
0) Make a less wide plate next to the usb plug. Sometimes they need to fit multiple plugs next to each other. e.g. keyboard and mouse and lorashark very close together. Lengthen the device to make it less wide.
1) 2 or 4 holes in the plate to be able to tighten the housing to the device. Or simply carry the device on a rope
2) make the device compatible with your current network
e64 wrote 02/25/2024 at 14:16 point
I need C API and library.,
Reimu NotMoe wrote 03/02/2024 at 18:07 point
Of course. You can use this as a start point: https://github.com/SudoMaker/Notkia/tree/master/Software/sources/lora
Reimu NotMoe wrote 08/10/2023 at 17:44 point
Replying to aaaaaa:
Yes.
sup wrote 08/09/2023 at 13:39 point
please add small screen and buttons
Not every person has a computer with them in an emergency situation. 5 or 10 keys is probably not a problem. The power consumption of the screen (which can be turned off without turning off the device) can be a problem I think.
Reimu NotMoe wrote 08/09/2023 at 18:13 point
Thanks for your suggestion. We have another project called the Wireless Terminal. It's a standalone LoRa handheld with T9 keypad and long battery life. https://twitter.com/ReimuNotMoe/status/1687600292769247233
aaaaaa wrote 08/13/2023 at 18:56 point
I no need info from you
Reimu NotMoe wrote 08/04/2023 at 20:29 point
Replying to aaaaaa:
I don't know how much RAM is needed by mruby, so I can't answer this question.
The Resonance runtime is hybrid C++ and JavaScript. Identical APIs are provided in both languages. It will be released on GitHub in a week or so.
Since the LoShark runs Linux, you can just use standard GCC toolchain to cross compile your stuff and access everything with POSIX and Linux APIs. Just like on a Linux PC (but keep in mind it only has 8MB RAM).
aaaaaa wrote 08/10/2023 at 09:32 point
https://www.rubyguides.com/2018/03/write-ruby-c-extension/ (You probably no needed module, only object)
ruby is simplest than javascript ,and fast
https://dev.to/juneira/creating-a-gem-using-ruby-c-api-4h5a
zyndram wrote 08/04/2023 at 13:56 point
1. Is possible install program on it? for example meshtastic or python RNode reticullum?
2. Is any C library ? I need ruby gem or python pip
Reimu NotMoe wrote 08/04/2023 at 15:53 point
The only limiting factor is 8MB RAM and everything else is the same as other Linux SBCs. You can select various software in buildroot or build them by yourself.
aaaaaa wrote 08/04/2023 at 17:18 point
mruby can run on it (pyton too)
question is C compiler and library in C to controle device.
library is only in JS, no in C?
