As of 2023-08-02, this comment appeared below the CNX software article. It appears to be from a upstream Linux maintainer.
And here are my responses:
- X1501 DO boot the latest 6.5-rc4 kernel using the X1000 target
- It's not our fault as fixes & new drivers of the X1000/X1501 can't be mainlined
- X1501 can't run systemd but it's still awesome with its 18mW standby power usage
- A PSRAM is not a NOR flash
LoShark (tested on X1501 EVB with LoShark's rootfs) running the latest rc kernel (with X1000 as target):
This is the complete boot log. Many things are broken, as expected. But you get a working shell.
X-Loader Build: 2023-06-28 - 19:08:31 EPC: 0x80101c24 stage2 inited uImage name: Linux-6.5.0-rc4-LoShark+ uImage size: 1020740 uImage load addr: 80100000 uImage endpoint addr: 8030cff4 Jumping to 8030cff4 [ 0.000000] Linux version 6.5.0-rc4-LoShark+ (root@Rinyuki-Laptop) (mipsel-linux-gnu-gcc (Ubuntu 9.4.0-1ubuntu1~20.04) 9.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #11 PREEMPT Thu Aug 3 04:13:47 CST 2023 [ 0.000000] CPU0 revision is: 2ed1024f (Ingenic XBurst) [ 0.000000] FPU revision is: 00330000 [ 0.000000] MIPS: machine is YSH & ATIL General Board CU1000-Neo [ 0.000000] earlycon: x1000_uart0 at MMIO 0x10032000 (options '115200n8') [ 0.000000] printk: bootconsole [x1000_uart0] enabled [ 0.000000] ********************************************************** [ 0.000000] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE ** [ 0.000000] ** ** [ 0.000000] ** This system shows unhashed kernel memory addresses ** [ 0.000000] ** via the console, logs, and other interfaces. This ** [ 0.000000] ** might reduce the security of your system. ** [ 0.000000] ** ** [ 0.000000] ** If you see this message and you are not debugging ** [ 0.000000] ** the kernel, report this immediately to your system ** [ 0.000000] ** administrator! ** [ 0.000000] ** ** [ 0.000000] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE ** [ 0.000000] ********************************************************** [ 0.000000] User-defined physical RAM map overwrite [ 0.000000] Initrd not found or empty - disabling initrd [ 0.000000] Primary instruction cache 16kB, VIVT, 4-way, linesize 32 bytes. [ 0.000000] Primary data cache 16kB, 4-way, VIPT, no aliases, linesize 32 bytes [ 0.000000] MIPS secondary cache 128kB, 4-way, linesize 128 bytes. [ 0.000000] Zone ranges: [ 0.000000] Normal [mem 0x0000000000000000-0x00000000007fffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000000000-0x00000000007fffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000007fffff] [ 0.000000] Kernel command line: console=ttyS2@115200n8 earlycon mem=8M@0x0 loglevel=7 devtmpfs.mount=1 clk_ignore_unused no_hash_pointers [ 0.000000] Dentry cache hash table entries: 1024 (order: 0, 4096 bytes, linear) [ 0.000000] Inode-cache hash table entries: 1024 (order: 0, 4096 bytes, linear) [ 0.000000] Built 1 zonelists, mobility grouping off. Total pages: 2032 [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] Memory: 4812K/8192K available (2122K kernel code, 141K rwdata, 220K rodata, 644K init, 86K bss, 3380K reserved, 0K cma-reserved) [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies. [ 0.000000] NR_IRQS: 256 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] clocksource: ingenic-ost: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1274173631191 ns [ 0.000003] sched_clock: 32 bits at 1500kHz, resolution 666ns, wraps every 1431655764658ns [ 0.008517] Calibrating delay loop... 1002.49 BogoMIPS (lpj=501248) [ 0.022791] pid_max: default: 4096 minimum: 301 [ 0.033908] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear) [ 0.041296] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear) [ 0.056642] rcu: Hierarchical SRCU implementation. [ 0.061517] rcu: Max phase no-delay instances is 400. [ 0.068357] devtmpfs: initialized [ 0.076543] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns [ 0.086469] futex hash table entries: 16 (order: -5, 192 bytes, linear) [ 0.094303] pinctrl core: initialized pinctrl subsystem [ 0.100175] cpuidle: using governor menu [ 0.118361] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.128163] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.138171] gpio gpiochip2: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.148548] gpio gpiochip3: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.160090] clocksource: Switched to clocksource ingenic-ost [ 0.181331] workingset: timestamp_bits=30 max_order=11 bucket_order=0 [ 0.190445] JFS: nTxBlock = 37, nTxLock = 300 [ 0.203735] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 0.213363] printk: console [ttyS2] disabled [ 0.218304] 10032000.serial: ttyS2 at MMIO 0x10032000 (irq = 49, base_baud = 1500000) is a 16550A [ 0.227393] printk: console [ttyS2] enabled [ 0.227393] printk: console [ttyS2] enabled [ 0.235777] printk: bootconsole [x1000_uart0] disabled [ 0.235777] printk: bootconsole [x1000_uart0] disabled [ 0.260853] loop: module loaded [ 0.264883] spi-ingenic 10043000.spi: DMA not available. [ 0.271533] spi spi0.0: Fixed dependency cycle(s) with /spi@10043000/expander@0/sc16is752 [ 0.281273] i2c_dev: i2c /dev entries driver [ 0.286304] jz4780-i2c 10050000.i2c-controller: Bus frequency is 400 KHz [ 0.298363] jz4740-mmc 13460000.mmc: Failed to get dma_tx channel [ 0.315647] dwc2 13500000.usb: Configuration mismatch. dr_mode forced to device [ 0.334842] dwc2 13500000.usb: dwc2_core_reset: HANG! Soft Reset timeout GRSTCTL_CSFTRST [ 0.342992] jz4740-mmc 13460000.mmc: Ingenic SD/MMC card driver registered [ 0.349931] dwc2: probe of 13500000.usb failed with error -16 [ 0.355762] jz4740-mmc 13460000.mmc: Using PIO, 4-bit mode [ 0.362022] clk: Not disabling unused clocks [ 0.372037] Freeing unused kernel image (initmem) memory: 644K [ 0.378117] This architecture does not have kernel memory protection. [ 0.384643] Run /init as init process [ 0.413297] mmc0: host does not support reading read-only switch, assuming write-enable [ 0.428333] mmc0: new high speed SDHC card at address 0001 [ 0.441179] mmcblk0: mmc0:0001 SD16G 29.2 GiB [ 0.454210] mmcblk0: p1 p2 [ 1.849133] random: crng init done /sys/class/leds/red:indicator/brightness: No such file or directory [ 1.854729] process '/jfs_fsck' started with executable stack jfs_fsck version 1.1.15, 04-Mar-2011 processing started: 1/1/1970 0:00:01 Using default parameter: -p The current device is: /dev/mmcblk0p1 Block size in bytes: 4096 Filesystem size in blocks: 32768 **Phase 0 - Replay Journal Log Filesystem is clean. mount: mounting debugfs on /sys/kernel/debug failed: No such file or directory mkdir: can't create directory '/run/lock/': Read-only file system vm.dirty_expire_centisecs = 1000 vm.min_free_kbytes = 64 Running sysctl: OK Starting Hardware: /sbin/init-hardware.sh: line 3: can't create /sys/class/leds/red:indicator/brightness: nonexistent directory OK Starting Storage: umount: can't unmount /mnt: Invalid argument cat: can't open '/sys/bus/spi/drivers/lyontek_ly68/*/mtd/mtd?/mtdblock?/dev': No such file or directory /dev/ly68psram*: No such file or directory error: failed to setup crypt loop for /dev/ly68psram* fsck.jfs version 1.1.15, 04-Mar-2011 processing started: 1/1/1970 0:00:02 Using default parameter: -p The current device is: /dev/mmcblk0p2 Block size in bytes: 4096 Filesystem size in blocks: 212736 **Phase 0 - Replay Journal Log Filesystem is clean. OK Starting USB gadget: OK Starting app: OK can't open /dev/ttyGS1: No such file or directory root@X1501:/# [ 2.982701] file system registered [ 3.097912] read descriptors [ 3.100937] read strings [ 4.099561] UDC core: g1: couldn't find an available UDC or it's busy [ 5.114977] UDC core: g1: couldn't find an available UDC or it's busy [ 6.130601] UDC core: g1: couldn't find an available UDC or it's busy [ 7.145878] UDC core: g1: couldn't find an available UDC or it's busy [ 8.161603] UDC core: g1: couldn't find an available UDC or it's busy [ 9.176967] UDC core: g1: couldn't find an available UDC or it's busy [ 10.192596] UDC core: g1: couldn't find an available UDC or it's busy [ 11.207900] UDC core: g1: couldn't find an available UDC or it's busy [ 12.223362] UDC core: g1: couldn't find an available UDC or it's busy [ 13.238825] UDC core: g1: couldn't find an available UDC or it's busy [ 16.422419] ffs_data_put(): freeing [ 16.525575] read descriptors [ 16.528606] read strings [ 17.526403] UDC core: g1: couldn't find an available UDC or it's busy [ 18.541900] UDC core: g1: couldn't find an available UDC or it's busy [ 19.557398] UDC core: g1: couldn't find an available UDC or it's busy [ 20.572869] UDC core: g1: couldn't find an available UDC or it's busy [ 21.588369] UDC core: g1: couldn't find an available UDC or it's busy [ 22.603853] UDC core: g1: couldn't find an available UDC or it's busy [ 23.619291] UDC core: g1: couldn't find an available UDC or it's busy [ 24.634773] UDC core: g1: couldn't find an available UDC or it's busy [ 25.650251] UDC core: g1: couldn't find an available UDC or it's busy [ 26.665713] UDC core: g1: couldn't find an available UDC or it's busy
Reimu NotMoe
