Short demo video:
Read more »DIY cloud chamber using a beefy CPU cooler and a single Peltier module too see ionizing radiation with your own eyes!
I tried the cloud chamber with a small piece of thorianite today, look for yourself:
Here's a small update, I stuck a little more PE tape to the glass around the LEDs so that the light doesn't dazzle so much. I also stapled a few resistors between the two layers of felt and attached them to the 12 volt rail of the power supply. This definitely allows you to see a lot more (especially on camera) now, so thanks for all the suggestions!
What is still missing is an extraction voltage of a couple hundred to maybe a thousand volts to extract all the extra electrons that are left over after the ionisation. That'll definitely help with visibility/contrast of the traces and how long it takes for them to clear up again. But I don't know if I'll do that yet. For this I would have to build a large frame inside the glass jar and get an high-voltage PSU module.
Put some thermal paste on the CPU cooler, where the processor would normally sit. Then mount the Peltier module onto it, so that most of the area is covered.
Cut the copper plate into a size of around 10 x 10 centimeters. Then drill four holes into the copper that match the location for the mounting screws of the CPU cooler mount.
Put some PE insulation tape on the bottom of the copper plate around the location where the peltier element will sit.
Hi there, that's a really good suggestion actually! Don't know why I didn't think of that, so... thanks! :D
What a wonderful detector! It looks like a very clean build.
If you cover the LEDs from the top, so they shine only in the middle, your eyes (and camera) sees more contrast of the traces. If you need even more light i used a strong laser (green) as line laser (shining it sideways through a LED)
best wishes, j
