Below I show you a estimate BOM cost. However you can reduce the total cost by replacing the rechargeable battery with a power supply.
BOM cost
The Excel document can be downloaded from the download section
Conclusion
- In this project I demonstrate the use of capsense sensors in the soldering and desoldering process of a PCB.
- I have used two Infineon PSoC™ 62S2 Wi-Fi BT Pioneer Kit boards, and they were programmed with ModusToolbox 3.0
Guillermo Perez Guillen
