FreindlyElec has its own WiringPi based library called WiringNP. It compiles with several warning massages. Trying to execute "gpio readall" in DietPi returns an error massage:
piBoardRev: Unable to determine board revision from /proc/cpuinfo -> Is not NanoPi based board. -> You may want to check: -> http://www.lemaker.org/ open /sys/class/sunxi_info/sys_info failed
While /proc/cpuinfo looks good in DietPi, sys/class/sunxi_info/sys_info doesn't exist. According to this workaround, you can redirect WiringNP to /etc/sys_info by editing WiringNP/wiringPi/boardtype_friendlyelec.c before executing ./build.
Original:
if (!(f = fopen("/sys/class/sunxi_info/sys_info", "r"))) { LOGE("open /sys/class/sunxi_info/sys_info failed."); return -1; }
Modified:
if (!(f = fopen("/sys/class/sunxi_info/sys_info", "r"))) { if (!(f = fopen("/etc/sys_info", "r"))) { LOGE("open /sys/class/sunxi_info/sys_info failed."); return -1; } }
In FriendlyCore for the NanoPi NEO Air sys_info looks like this:
sunxi_platform : sun8iw7p1 sunxi_secure : normal sunxi_chipid : unsupported sunxi_chiptype : unsupported sunxi_batchno : unsupported sunxi_board_id : 2(0) board_manufacturer: FriendlyElec board_name : FriendlyElec Nanopi-NEO-Air
With this workaround "gpio readall" returns the expected output:
+-----+-----+----------+------+---+-NanoPi-NEO-Air--+------+----------+-----+-----+ | BCM | wPi | Name | Mode | V | Physical | V | Mode | Name | wPi | BCM | +-----+-----+----------+------+---+----++----+---+------+----------+-----+-----+ | | | 3.3V | | | 1 || 2 | | | 5V | | | | 12 | 8 | GPIOA12 | ALT5 | 0 | 3 || 4 | | | 5V | | | | 11 | 9 | GPIOA11 | ALT5 | 0 | 5 || 6 | | | 0v | | | | 203 | 7 | GPIOG11 | OFF | 0 | 7 || 8 | 0 | OFF | GPIOG6 | 15 | 198 | | | | 0v | | | 9 || 10 | 0 | OFF | GPIOG7 | 16 | 199 | | 0 | 0 | GPIOA0 | OFF | 0 | 11 || 12 | 0 | OFF | GPIOA6 | 1 | 6 | | 2 | 2 | GPIOA2 | OFF | 0 | 13 || 14 | | | 0v | | | | 3 | 3 | GPIOA3 | OFF | 0 | 15 || 16 | 0 | OFF | GPIOG8 | 4 | 200 | | | | 3.3v | | | 17 || 18 | 0 | OFF | GPIOG9 | 5 | 201 | | 64 | 12 | GPIOC0 | OFF | 0 | 19 || 20 | | | 0v | | | | 65 | 13 | GPIOC1 | OFF | 0 | 21 || 22 | 0 | OFF | GPIOA1 | 6 | 1 | | 66 | 14 | GPIOC2 | OFF | 0 | 23 || 24 | 0 | OFF | GPIOC3 | 10 | 67 | +-----+-----+----------+------+---+----++----+---+------+----------+-----+-----+ | BCM | wPi | Name | Mode | V | Physical | V | Mode | Name | wPi | BCM | +-----+-----+----------+------+---+-NanoPi-NEO-Air--+------+----------+-----+-----+ +-----+----NanoPi-NEO-Air USB/Audio-+----+ | BCM | wPi | Name | Mode | V | Ph | +-----+-----+----------+------+---+----+ | | | 5V | | | 25 | | | | USB-DP1 | | | 26 | | | | USB-DM1 | | | 27 | | | | USB-DP2 | | | 28 | | | | USB-DM2 | | | 29 | | | | IR-RX | | | 30 | | 17 | 19 | GPIOA17 | OFF | 0 | 31 | | | | PCM/I2C | | | 32 | | | | PCM/I2C | | | 33 | | | | PCM/I2C | | | 34 | | | | PCM/I2C | | | 35 | | | | 0V | | | 36 | +-----+-----+----------+------+---+----+ +-----+----NanoPi-NEO-Air Debug UART-+----+ | BCM | wPi | Name | Mode | V | Ph | +-----+-----+----------+------+---+----+ | 4 | 17 | GPIOA4 | ALT5 | 0 | 37 | | 5 | 18 | GPIOA5 | ALT5 | 0 | 38 | +-----+-----+----------+------+---+----+
I was surprised to see, that in FriendlyCore the DS3231 RTC was automatically assigned to /dev/rtc1. I still had to manually sync the system time to it.
