Adding the extra wire cover piece, switches and touch pad to the keyboard panel
JPEG Image - 3.69 MB - 07/31/2023 at 19:36
Preview
Creating the back panel for the 10.1 inch touchscreen.
JPEG Image - 4.36 MB - 07/31/2023 at 19:36
Preview
Attaching the panel supports that accept screws to the Pi panel.
JPEG Image - 3.42 MB - 07/31/2023 at 19:36
Preview
Attaching the legs from the 7 inch touchscreen enclosure to the panel the resides behind the 10.1 inch touchscreen.
JPEG Image - 3.01 MB - 07/31/2023 at 19:36
Preview
Internal view of behind the touchscreens
JPEG Image - 3.22 MB - 07/31/2023 at 19:36
Preview
Keyboard panel cut, edges rounded and keyboard hole cut out.
JPEG Image - 2.94 MB - 07/31/2023 at 19:36
Preview
Velcro placed on GPS mouse.
JPEG Image - 3.04 MB - 07/31/2023 at 19:36
Preview
Making Pi panel supports that accept screws.
JPEG Image - 3.07 MB - 07/31/2023 at 19:36
Preview
Panel that will go behind the 10.1 inch touchscreen and legs from 7 inch touchscreen enclosure
JPEG Image - 3.64 MB - 07/31/2023 at 19:36
Preview
Panel placed over Pi and Pi mount, screen mount is not obstructed by panel.
JPEG Image - 2.98 MB - 07/31/2023 at 19:36
Preview
10.1 inch touchscreen mounted, wires ran, mount articulated.
Preview
Power switch has industrial strength glow powder in the UV resin.
JPEG Image - 2.93 MB - 07/31/2023 at 19:36
Preview
Webcam mounted to Pi panel
JPEG Image - 3.16 MB - 07/31/2023 at 19:36
Preview
Keyboard panel secured with 3d printing pen
JPEG Image - 2.90 MB - 07/31/2023 at 19:36
Preview
Custom legs added to the bottom of the Top portion of the case to create balance and help to support the weight.
JPEG Image - 2.82 MB - 07/31/2023 at 19:36
Preview
Slit cut for webcam on Pi panel.
JPEG Image - 2.84 MB - 07/31/2023 at 19:36
Preview
Panel will be placed on back of touchscreen.
Preview
Supports placed on the bottom of the keyboard panel.
JPEG Image - 2.61 MB - 07/31/2023 at 19:36
Preview
Power switch glowing
JPEG Image - 2.51 MB - 07/31/2023 at 19:36
Preview
Extra supports fabricated out of plastic panel placed under top of keyboard opening to ensure no weight is placed on the USB plugs.
JPEG Image - 2.55 MB - 07/31/2023 at 19:36
Preview
7 inch screen in screen enclosure
JPEG Image - 2.60 MB - 07/31/2023 at 19:36
Preview
Panel placed on back of 10.1 inch panel.
JPEG Image - 2.88 MB - 07/31/2023 at 19:36
Preview
How 10.1 inch screen will sit when case is closed
JPEG Image - 2.72 MB - 07/31/2023 at 19:36
Preview
Both the 10.1 and 7 inch screens are installed, the Pi panel is currently off
JPEG Image - 2.70 MB - 07/31/2023 at 19:36
Preview
Pi and Pi case / support placed and 10.1 inch touchscreen mount placed also.
JPEG Image - 2.53 MB - 07/31/2023 at 19:35
Preview
Holes cut for ports on the panel the resides behind the 10.1 inch panel.
JPEG Image - 2.52 MB - 07/31/2023 at 19:35
Preview
7 inch touchscreen mount placed.
JPEG Image - 2.72 MB - 07/31/2023 at 19:35
Preview
Pi panel supports that do not accept screws placed.
JPEG Image - 2.64 MB - 07/31/2023 at 19:35
Preview
Hardware build complete!
JPEG Image - 2.60 MB - 07/31/2023 at 19:35
Preview
Webcam placed on Pi panel
JPEG Image - 2.51 MB - 07/31/2023 at 19:35
Preview
Nano tape strip laid for 10.1 inch touchscreen mount
JPEG Image - 2.54 MB - 07/31/2023 at 19:35
Preview
webcam ribbon attached to Pi
JPEG Image - 2.50 MB - 07/31/2023 at 19:35
Preview
Running the wired from the Pi
Preview
Screen fits!
Preview
Wires ran for 10.1 inch screen
JPEG Image - 2.47 MB - 07/31/2023 at 19:35
Preview
Pi panel mounted
JPEG Image - 2.39 MB - 07/31/2023 at 19:35
Preview
RTL-SDR dongle attached to the side of the case with Velcro.
JPEG Image - 2.37 MB - 07/31/2023 at 19:35
Preview
7 port USB hub mounted behind the 7 inch screen.
JPEG Image - 2.30 MB - 07/31/2023 at 19:35
Preview
Pi panel cut, bottom edges rounded.
JPEG Image - 2.31 MB - 07/31/2023 at 19:35
Preview
Power block mounted behind the 10.1 inch screen with nano tap.
JPEG Image - 2.28 MB - 07/31/2023 at 19:35
Preview
RTL-SDR dongle mounted above the webcam with Velcro.
JPEG Image - 2.17 MB - 07/31/2023 at 19:35
Preview
Working with 10.1 inch screen in upright position
JPEG Image - 2.13 MB - 07/31/2023 at 19:35
Preview
GPS mouse mounted with Velcro.
JPEG Image - 2.18 MB - 07/31/2023 at 19:35
Preview
High power magnets mounted to both the 10.1 inch mount arm and inside top of the case to create the force//support needed to keep that screen upright when you want it upright
JPEG Image - 2.09 MB - 07/31/2023 at 19:35
Preview
Spacer that was cut to try and tighten up the 10.1 inch mount arm, in the end this was thrown out as it was useless and replaced with high power magnets.
JPEG Image - 2.06 MB - 07/31/2023 at 19:35
Preview
black Vinyl for the magnet so it's not shiny
JPEG Image - 1.98 MB - 07/31/2023 at 19:35
Preview
Panel behind the 10.1 inch touchscreen placed.
Preview
Supports for under the keyboard panel.
JPEG Image - 1.92 MB - 07/31/2023 at 19:35
Preview
GPS mouse mounted inside the case with Velcro
JPEG Image - 1.87 MB - 07/31/2023 at 19:35
Preview
Where the spacer went that failed and was replaced with magnets.
JPEG Image - 1.76 MB - 07/31/2023 at 19:35
Preview
Pi panel support that accepts screws complete
JPEG Image - 1.67 MB - 07/31/2023 at 19:35
Preview
Pi panel supports that do not accept screws complete
JPEG Image - 1.68 MB - 07/31/2023 at 19:35
Preview
