Hackaday.io Hackaday.io
Sign up Log in
USB switch for Keyboard/Mouse
Easy switching your keyboard and mouse between devices using keyboard shortcuts, based on rp2040
biemsterbiemster
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1 comments
5 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 1
714
1
5
2
Team (1)
  • biemsterbiemster
Join this project's team
hardware
ongoing project
RP2040 KVM switch usb
This project was created on 08/02/2023 and last updated 3 years ago.
Description
There are several machines in my shack that require keyboard/mouse input semi-regularly. For example a laptop and a workstation, Raspberry Pi's and older hardware like a 2010 iMac.
I find myself plugging in and out my USB keyboard/mouse on these devices way too much, which is not only annoying but will also wear out the connectors. This project will address that issue.
The plan is to give a Pi Pico a single connection to a keyboard/mouse (my keyboard has a built-in USB hub but an external hub should work too), and on the other side have multiple connections to the USB ports on the machines needing keyboard input.
On top of that I need those machines to initialize the USB peripheral when switched, so on top of a simple pass-through of the USB data the Pico also needs to perform some form of proper dis/connecting of the keyboard or hub. And analyse the USB packets for a key combo to switch the output ports and light an LED indicating which one is active.
Project Logs
Collapse
  • Interesting projects with code that might help
    biemster • 08/02/2023 at 13:50 • 0 comments
    First thing is to browse what code is already out there, these are the ones I found so far:
    https://github.com/ataradov/usb-sniffer-lite
    https://github.com/tana/pico_usb_sniffer
    https://github.com/sekigon-gonnoc/Pico-PIO-USB
    Especially that last project seems very versatile, if I end up needing more than simply switching the input (keyboard/mouse) packets to different pins on the Pico.
View project log
Log In/Sign up to comment
Sign up with Github
OR
ams1 wrote 06/07/2024 at 14:01 • point
Hi, great project - are you still working on this?
another usb modification of the folding keyboards for the old Palm PDAs that puts all electronics inside the the folded case
Project Owner Contributor
Palm Portable Keyboard USB mod
johschneiderJohSchneider
Making a really old mechanical keyboard USB
USB adapter for Apple ADB keyboard
benchoffBenchoff
A mechanical keyboard in KiCad, manufactured in China
Mechanical Keyboard
travis-ayresTravis Ayres
Fits into the keyboard as though it were designed for this.
Keyboard with Apple Mouse Scroll Ball
gertlexGertlex
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "USB switch for Keyboard/Mouse", please tell us the reason.
Send message
Remove Member
