1Use a long Torx T15 driver to open the Mac SE
This is something similar to what I use: https://console5.com/store/t15-macintosh-case-tool-for-128k-plus-se-se-30-classic-t15h-extended-1-4-drive.html
2Carefully remove the cover off after the screws are removed
3Install the fan shroud to the fan
4Carefully remove the old fan -- in my case I used a small nut driver and a Phillips style screwdriver
5Reuse the old screws to attach the new fan.
6Using the Molex adapter, plug the fan into power and test.
