• Successful wash!
    David H. Bronke08/21/2023 at 18:03 0 comments
    Note: This log was actually written in August 2023, but apparently was never published. I'm publishing it now, since this is basically where I left off with the dishwasher - it works, though it's now in storage because we moved.
    I did manage to get the dishwasher fixed; it seems like the "water softener regen valve" wires I found actually control _both_ valves: the one for switching the inlet to flow into the brine tank, and the one for draining spent brine. Just switching it on and turning the inlet valve on at the same time regenerates the water softener resin quite nicely! I've pushed the latest code to the GitLab project. (https://gitlab.com/whitelynx/esp32-dishwasher)
