Press-fit connector installation
12/12/2023 at 21:01 • 0 commentsJust a quick note on how I installed the press fit connectors:
Gerbers and PCB BOM
09/01/2023 at 03:06 • 0 comments
I uploaded the gerber files with fab instructions for the mini PCIe backplane. Enjoy!
Mechanical files to come.
Total component cost for the mini backplane as of today, from DigiKey is $59Shared cart:
https://www.digikey.com/short/q3d7hmqjList of parts:
DigiKey Part Number Manufacturer Part Number Description Qty Unit Price Ext Price A123726-ND 2227595-1 CONN MINI HD SAS RCPT 36POS PCB 1 7.02 7.02 2684-973062-ND 973062 ZD M 3-10 30POS 1.7MM 1 16.11 16.11 A144744-ND 2336514-1 2MM HM MALE CONNECTOR, COL 8, M2 2 10.67 21.34 507-1948-1-ND 0685T5000-01 FUSE BRD MNT 5A 63VAC 63VDC 1206 3 0.32 0.96 2057-SATA-G-PM-SMT-ND SATA-G-PM-SMT SATA CONNECTOR 2 2.71 5.42 478-9397-1-ND TCJD107M025R0055 CAP TANT POLY 100UF 25V 1210 3 2.58 7.74 RMCF0603ZT0R00CT-ND RMCF0603ZT0R00 RES 0 OHM JUMPER 0.1W 0603 1 0.1 0.10 -
GNU Radio hello world
08/30/2023 at 04:00 • 0 commentsAfter quite a bit of struggle I managed to get a GNU Radio source block going for the VST analyzer part.
It's very basic at the moment, but it builds and runs.I never really had a plan about how far to take this, so for the moment I just enjoy hating everything related, like conda, c++, pybind and a million other things that I have no (usable) knowledge about. I'm learning a lot and that's good.
Rev B is alive!
08/21/2023 at 03:54 • 0 comments
A lot quieter, runs cooler, looks better.Next I'll build another mini-backplane pcb to try 2 instruments side-by-side. Unfortunately the refurb dell motherboard I'm using doesn't support PCIe bifurcation so I'll need two separate miniSAS adapter cards, but I still have empty slots.
Power
08/15/2023 at 23:25 • 0 commentsOne of the nice things about this whole concept is that -by coincidence- there is no need to mess with a power supply / regulator circuitry for the PXIe instrument.
In general a module needs a +12V and a +3.3V rail and a +5V with negligible current draw. In case of the PXIe-5644R the spec sheet says the following:
+3.3V..............4.9A (5.3A max)
+12V................3.3A (4.2A max)Since I didn't want to connect any disks to the same SATA power lines, I decided to make new point to point cables for them
Rev B assembled
08/10/2023 at 01:07 • 0 commentsRev B cage assembled.
I'm very happy with how the mechanical integration came together. There are a couple of screw holes that don't line up with the PC case, but the cage is still held firm.
Tell me it doesn't look like it came out of a factory.
Mini backplate schematics
08/08/2023 at 06:32 • 0 commentsI uploaded the sch for the mini backplane.
Not a lot to see here.
The difficult part was to figure out the signal assignment through the MiniSAS link.
MiniSAS HD is an SNIA spec, namely SFF-8643. Standard documents have tables detailing how PCIe can be routed over the cables and connectors of the interface. I bought a PCIe-MiniSAS HD adapter board on Amazon but that didn't follow the pinout in the SINA documents. These kind of adapter boards are used for storage devices, so I'm sure there's a reason why their signals assignment is that way, but I couldn't make sense of it so I had to reverse engineer based on the hardware.
Mini backplane PCB pics
08/07/2023 at 15:53 • 0 commentsThe adapter electronics are quite simple. The difficulty was figuring out pinouts and part selection.
Rev B cage design
08/06/2023 at 00:37 • 0 commentsRev B cage design for SilverStone SETA D1 Mid-Tower case
Random pics
08/06/2023 at 00:34 • 0 commentsRev A cage
Rear view on my desk. MiniSAS HD connector for PCIe, sata connectors for power.
